valve to control air flow?
Posted: Tue Jun 11, 2019 11:03 am
by kriznik
hello,
iam seeking for a valve like solenoid but which can be controlled like steppers motors eg not only on/off as solenoids.
is there anything like that out there?
i was briefly looking around but found mostly solenoids applications which is not really suitable for what iam looking for.
thanks for any hints
Re: valve to control air flow?
Posted: Tue Jun 11, 2019 12:12 pm
by Andyroo
Welcome to the forum
I remember the TV show Mythbusters doing something similar but no idea how much their rig cost.
Could you adapt this to your needs https://blog.arduino.cc/2017/08/29/regu ... h-arduino/ - it ‘cheats’ by using pulses to control a hand held air gun :lol:
For a real solution you will need to describe your needs a bit more inc what pressure (and possibly gas) you are working with.
Posted: Tue Jun 11, 2019 12:24 pm
by pcmanbob
Motor controlled valves are used a lot in industry to control the flow of liquids, whether they will be suitable for air I don't know and they tend to be expensive when compared to solenoid valves
some examples
http://trends.directindustry.com/u-k-mu ... 33987.html
https://www.akmueller.de/en/products/pr ... alve-dn10/
Posted: Tue Jun 11, 2019 12:29 pm
by kriznik
hi and thank you ;)
ok so bit more details about what I'm looking for.
I do have an Air compressor with 130litres/min and not so high pressure, this compressor provides air around my outdoor lake.
That compressor is connected to two branches, one for one side, second for second side, connected by T so:
        Branch A
|   Compressor  +---------------| | needed valve
                                |                                 Branch B
"needed valve" is point where I need to put something to control flow to eiter both branches or indeed it can be placed on BRANCH A and control flow there.
Currently because branch B is longer, branch A is easier for air to go thru and so Branch B at the end lacking air, I basically need control flow to the branch A to allow more air to branch B.
If it is understandable :)
Indeed i can have manual valve which I can set once and leave it there for good, but ... since we are nerds and we like to control simple stuff complicated way ... am asking :P
Posted: Sat Jun 15, 2019 3:24 pm
by omegaman477
hi and thank you ;)
        Branch A
                                |                                 Branch B
I think a large air reservoir tank is all thats needed. And maybe a throttling needle valve feeding each branch.
Posted: Sat Jun 15, 2019 8:43 pm
by PhatFil
i agree try balancing the pressures with flow restriction, a strategically placed needle valve or 2 should do it. a really smart system could detect air flow at each outlet and manage the needle valves with servo control perhaps?
Posted: Sat Jun 15, 2019 8:44 pm
by PhatFil
error
