JLFirestone1997
Robotics project PLEASE HELP!
Wed Apr 17, 2019 9:53 pm
So I started building my first robot the other day and I got this Raspberry motor shield that has no documentation I wired the motors to motor 1 and 2 but whenever I run the code to detect the motors they aren't detected and I can't figure out what I'm doing wrong the board works and the light comes on any one have any ideas?
Andyroo
Re: Robotics project PLEASE HELP!
Wed Apr 17, 2019 11:27 pm
My guess is the board needs an external supply as well as the Pi GPIO output esp. as it has connection for this :D
From here the GPIO can only deliver 50mA in total
Where did you get the board from - they may have a web site?
MrEngman
Thu Apr 18, 2019 12:15 am
Not sure if this is what you need but it looks as though it may be - https://github.com/sbcshop/MotorShield
Various bits of documentation and code.
pcmanbob
Thu Apr 18, 2019 12:02 pm
Looking at the schematic digram in the link posted you need to connect a 12VDC power supply to the indicated terminal to power the motors from, making sure to connect it the right way round.
The 5v from the pi will only drive the electronics/control circuit and not the motors.
JLFirestone1997
Thu Apr 18, 2019 3:45 pm
Wow! A big thank you to everyone! I'm ordering a separate power supply for the board now the one I had wasn't out putting enough power. :D :lol:
Does anyone have any suggestions for a portable power supply that can output 12vdc?
Brandon92
Thu Apr 18, 2019 4:57 pm
A portable power supply would be a battery. For example a lead acid battery or a NIMH battery from the RC world will do the job. And of course a lipo battery will work also, but you need to have some protection with it.
JLFirestone1997
Mon Apr 22, 2019 12:18 am
So I got the a 12 v AA battery pack and connected it to the suggested ports its now pulling 12.5 v however the motor ports are still drawing nothing when I test them with a multi meter? :/
pcmanbob
Mon Apr 22, 2019 11:37 am
Have you tried running the motor test program Test_Motor.py on the GitHub page MrEngerman posted the link to.
That should just drive all motors in a test pattern.
