jon wise
Boules
Thu Mar 21, 2019 8:43 am
A game of boules could be improved by simplifying the measurement of the relative distances between two balls and the jack. It could be simplified by taking an image vertically down over the jack, recognising the three circles and calculating the distances. What pattern recognition software could I try on a Raspberry Pi?
scotty101
Re: Boules
Thu Mar 21, 2019 10:43 am
OpenCV and Python.
Task will be significantly easier if you use brightly coloured balls that have a high contract from each other and the background. Silver Balls on sand won't be a good contrast.
OpenCV will be able to filter the image by colours and then detect circles. Once you've detected the circles you can measure how many pixels apart they are.
Getting the camera in a good position might be challenging though.
You might want to start your project by testing the positioning of the camera and take some test photos which you can then use to develop your code. Then if you get stuck you can share the code and the photos with others to ask for help.
omegaman477
Re: Boules
Fri Mar 22, 2019 9:05 am
Use a high contrast IR filter on the camera lens and they should shine like crazy. At night you will need IR illumination from some IR leds.
..the only thing worse than a stupid question is a question not asked.
jon wise
Re: Boules
Mon Mar 25, 2019 10:26 am
Could you please offer more advice on the IR filter. My first attempt with a standard image does not recognize the outline of the shiny balls.
scotty101
Re: Boules
Mon Mar 25, 2019 1:28 pm
I say again
Share some photos.
