Mattyhawk
Cam Jam Edukit 3
Sun Feb 10, 2019 12:27 pm
I was coding 7-pwm.py
Then I ran the code but it came up with this error:
"Traceback (most recent call last):
File "/home/pi/Edukit3/CamJam Edukit 3 - GPIO Zero/Code/7-pwm.py",
line 17, in <module>
robot.value = motorforward
File "/usr/lib/python3/dist-packages/gpiozero/devices.py", line 299,
in __setattr__
return super(CompositeDevice, self).__setattr__(name, value)
File "/usr/lib/python3/dist-packages/gpiozero/devices.py", line 146,
in __setattr__
return super(GPIOBase, self).__setattr__(name, value)
AttributeError: can't set attribute"
Can you help me fix it?
ps. this is the code that I am using:
"# CamJam EduKit 3 - Robotics
# Worksheet 7 - Controlling the motors with PWM
import time # Import the Time library
from gpiozero import CamJamKitRobot # Import the GPIO Zero Library CamJam library
robot = CamJamKitRobot()
# Set the relative speeds of the two motors, between 0.0 and 1.0
motorspeed = 0.5
motorforward = (motorspeed, motorspeed)
motorbackward = (-motorspeed, -motorspeed)
motorleft = (motorspeed, 0)
motorright = (0, motorspeed)
time.sleep(1)
robot.value = motorbackward
time.sleep(1) # Pause for 1 second
robot.value = motorleft
robot.value = motorright
robot.stop()"
