Buffer of ADC overflows?
Posted: Thu Nov 15, 2018 6:19 pm
by ricardo.santos
Hi all
I'm doing a acquisition system for analog sensors (water pressures and water turbidity) using a raspberry pi 3B and a ADC (ADS1115).
The problem that i am facing is that from time to time the buffer (or whatever) gets full and the ads1115 gives a zero reading.
The lower the data rate (or whatever), the more frequente are the nulls.
Here I show the plots that i have:
DATA RATE = 8 sps
DATA RATE = 16 sps
The drops were turbidity goes to zero and pressure to negative values are a consequence of the zero readings in the adc.
Is there a way to clear the buffer (or whatever) of the adc? Or do you think the problem is other?
The connections that i have are all in the github repository: https://github.com/Ricardosgeral/relier ... /README.md
The code for the reading of the ADS1115 is in this file https://github.com/Ricardosgeral/relier ... _thread.py
I would appreciate some directions here.
Re: Buffer of ADC overflows?
Posted: Thu Nov 15, 2018 11:24 pm
by OutoftheBOTS
It is the software your using.
The AD1115 doesn't have a buffer it just has constally reads and stores the lastest conversion in its register.
The software your using has a thread that is started when you call the function run() that reads the ADS1115 then stores the data in a buffer then when you call the function read_analog() it returns the average of all the data stored in the buffer and then resets the buffer to start filling again.
Your problem will be when this buffer gets full as it isn't a ring buffer so it overflows. The better way to use a buffer to store a constant flow of data so that you can average is to use a ring buffer. A ring buffer when full then starts to write back at the beginning again instead of overflowing.
Posted: Fri Nov 16, 2018 10:28 am
by ricardo.santos
ohh thanks. That makes sense.
I will investigate that ring buffer. I don't know how to implement it.
Posted: Fri Nov 16, 2018 3:12 pm
by ricardo.santos
I have another question!
Is there a way to know if a pin of the ADS1115 has no sensor attached?
thank you
Posted: Sat Nov 17, 2018 6:15 am
by OutoftheBOTS
If there isn't anything attached to the ADC pins then it should read zero or very very close to it :)
Posted: Sun Nov 18, 2018 4:39 am
by OutoftheBOTS
Instead of using the mean(average) of the ADC readings it is usually better to use the median see this video for better explanation https://youtu.be/H51OzQl3BC8
Posted: Tue Nov 20, 2018 10:04 pm
by Brandon92
Well I think that is not correct. You will measure anything and everything between the 0 and the maximal value, if the input of the ADC is floating. This is because the input impedance of the ADC is high, in this case between the 3M -100M Ohm. And it will pick up any noise, signals, ect. that are in the air. So, basely the values are random that you will get.
