zchan
Running a pi 3, DC Motor Hat, and Google Voice Hat off of batteries
Mon Sep 03, 2018 8:39 am
I am stacking a Google voice hat on top of a E336755 Adafruit DC motor hat on top of a raspberry pi 3. The Google Voice hat has an option to run batteries to it if you cut a solder joint. The DC motor hat also has a terminal for batteries. Do I need to run power to both? One? Which one?
Are 4 AA batteries enough to run 2 1.2A dc motors, 2 servos, 1 metal gear servo, a pi 3, google voice hat, and dc motor hat?
Thanks!!
pcmanbob
Re: Running a pi 3, DC Motor Hat, and Google Voice Hat off of batteries
Mon Sep 03, 2018 9:12 am
Looking at your proposed build some point that jump out at me.
1. You can't stack to hats if they are true hats with an EPROM on.
2. 4 x AA batteries are not going to run 2 x motors drawing 1.2A for very long especially if you are running servos as well.
3. You have made no provision for supping 5v to your pi, ( 4 x AA = 6v ) which should have its own power source separate from the motors power source.
