Re: What motion sensors suitable for drones, work with a Pi ?
Posted: Wed Aug 15, 2018 10:39 am
by scotty101
Insurmountable wrote:
Wed Aug 15, 2018 12:35 am
so how come this project forum isn't full of drone projects?
1. There are some drone project
2. Drones aren't easy. In theory they are simple but in practice they are a lot more complicated
Many drones will use a 'simpler' microcontroller rather than a complex SoC like the Pi. For example the ArduPilot controller uses ATMega microcontrollers. Advantage is that they require less power and will 'boot' quicker than a Pi with a full OS will.
It is certainly possible to create a drone with a Pi (since it has been done) but you'll need a bigger battery for similar flight times.
Posted: Thu Aug 16, 2018 8:12 am
by OutoftheBOTS
When you say motion sensor you mean IMU. Most people will use a MPU9250 and it can be connected either via I2C or SPI. But do realize it is a complex matter to get absolute orientation from them.
Posted: Fri Aug 17, 2018 6:25 am
by Gavinmc42
Broadcom haven't fixed the problem with their I2C interface
What OS/Language are you using?
I gave up on i2c + Linux and now use Ultibo(baremetal), works fine.
Have not tried Ultibo for drones yet.
