Water sensor for a (deep) well
Posted: Fri Aug 03, 2018 4:26 pm
by L0r3n20
Hi all!
I would like to use blmy RPI to measure the level of the water in a well that goes down to 14 m. I was thinking about using the hc-sr04 but it seems to be limited in range. What can I use? I need something that alerts me when the water goes below a certain level (let's say when there are just a couple of meters more). Thank you in advance!
Re: Water sensor for a (deep) well
Posted: Sun Aug 05, 2018 7:53 pm
by Brandon92
If you just want a indication, if the water is below a certain point. You can use something like this. The only down-side is that you need to add this sensor to a pole. You can also use something like this if you can make it 100% waterproof. But with the same down-side.
Posted: Tue Aug 14, 2018 8:21 pm
by CFLanger
guided wire radar.
Posted: Wed Aug 15, 2018 2:46 am
by Insurmountable
NO OPTION TO DELETE MY ACCOUNT
Posted: Thu Aug 16, 2018 12:08 pm
by L0r3n20
First of all thanks for the replies. Insurmountable answers seems rather complicated (at least for me) and there is too much risk of getting the speaker wet (the well is not airtight).
CFLanger can you explain please?
Brandon92 seems the best option for now. :)
