Johnny445
Pi-Plate not working, really no idea what's wrong
Wed Jul 25, 2018 12:55 am
So, I have a Pi-Plate (DAQC2Plate specifically). I have installed all the Python libraries, enabled SPI, literally did everything that the Pi-Plate site tells me to do, and pretty sure I connected the Pi-Plate to my Pi correctly since the white LED turns on. Now, the problem is, I am trying to change the color of the built in LED with the setLED(addr,color) command that is supposed to work. But I keep getting an error. I really have no idea at all what the error could stem from; I've tested it on two different models of perfectly working Pis, so it must be the Pi-Plate. I've rebooted, reinstalled and uninstalled everything but it just doesn't work. Any idea what's wrong? I need this Pi-Plate for a more advanced project; I will be doing data acquisition with it, but if I can't even get this most basic function working, I don't know what I'll do. Some pictures for reference:
https://i.redd.it/f9ac6fnqrzb11.png (Note: I know the default address is zero, but I did set it to 7 for this particular trial.)
https://i.redd.it/36sw5khwrzb11.png
Any help is appreciated please. I've scoured all over the Pi-Plate site but can't seem to find any info that helps.
The Traveler
Re: Pi-Plate not working, really no idea what's wrong
Wed Jul 25, 2018 1:11 am
Let's look at your code. It appears you have a variable that is not set. We'll start with "setLED is not defined" and your import statement.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
PhatFil
Wed Jul 25, 2018 1:51 am
+1
Start with the first error you get, anything spat out later could be tainted by error#1, fix error #1 and everything else could well fall into place..
a quick look at the code example at the bottom of this page https://pi-plates.com/daqc2-users-guide/
suggests the command
DAQC2.setLED(x.y)
might be what you ment to type?
if the setled function is a method of the daqc2 instance
Johnny445
Wed Jul 25, 2018 3:07 am
+1
DAQC2.setLED(x.y)
Thank you, I will try this next time I have access to it and get back, although I'm pretty sure I must have tried this, without doing any wrong commands beforehand.
