H.A
sim808 and waze
Wed Jul 18, 2018 5:10 am
Hi guys, I'm trying to run a gps -sim808- and waze on my car.
What i need :
Monitoring gps data with waze and sending to my I-home device.
What i did :
connected sim 808 (serial to usb to /dev/ttyUSB)- reading data with a simpe python code is ok/
5 inch touch screen lcd installed and running
USB GSM modem installed and running -sim800c
And now :
cgps data does not show any gps data - gpsd is running
I am Unable to register new user in waze - it does not working after i inserted user/pass data account - no where to press register !
rpi3
raspbian 4.14.52-v7+
sim808 gps module
sim800c gsm usb
H.A
Re: sim808 and waze
Thu Jul 19, 2018 6:45 am
Today I see new issue
Jul 19 11:14:42 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:14:45 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:14:48 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:14:51 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:14:54 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:14:57 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
Jul 19 11:15:00 rpi3 gpsd[3780]: gpsd:INFO: KPPS:/dev/ttyUSB0 kernel PPS timeout Connection timed out
:roll:
H.A
Re: sim808 and waze
Sun Jul 22, 2018 10:53 am
NO ONE CAN SEE THIS ?OR THIS POST IS JUST VISIBLE TO me ?
The Traveler
Re: sim808 and waze
Sun Jul 22, 2018 11:51 am
It's been seen 127 times so far. No one has an answer to your question apparently.
Then there is this:
Waze supports Android and iPhone ... ... do not support either a full native UI or other application programming interfaces they rely on
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
H.A
Re: sim808 and waze
Sun Jul 22, 2018 12:51 pm
The problem is gpsd ! not waze !
Now !
I'm trying to troubleshoot what is problem when i run cgps and i can not see any request to my device
Jul 22 17:22:10 rpi3 gpsd[1161]: gpsd:PROG: checking client(0)
Jul 22 17:22:10 rpi3 gpsd[1161]: gpsd:INFO: detaching ::1 (sub 0, fd 8) in detach_client
Jul 22 17:22:10 rpi3 gpsd[1161]: gpsd:CLIENT: => client(0): {"class":"VERSION","release":"3.16","rev":"3.16-4","proto_major":3,"proto_minor":11}\x0d\x0a
Jul 22 17:22:10 rpi3 gpsd[1161]: gpsd:CLIENT: <= client(0): ?WATCH={"enable":true,"json":true};\x0a
Jul 22 17:22:10 rpi3 gpsd[1161]: gpsd:CLIENT: => client(0): {"class":"DEVICES","devices":[]}\x0d\x0a{"class":"WATCH","enable":true,"json":true,"nmea":false,"raw":0,"scaled":false,"timing":false,"split24":false,"pps":false}\x0d\x0a
ps auxw | egrep waze
root      1410  0.1  2.7  41784 26120 pts/3    S+   16:29   0:03 waze
Thanks.
H.A
Re: sim808 and waze
Mon Jul 23, 2018 3:27 pm
I wrote a script in python to do some acts instead of gpsd.
But ! i it seems i do not have knowledge about communication between gpsd and clients !.
Re: sim808 and waze
Mon Jul 23, 2018 9:13 pm
If you've got gpsd running then the agps3 package gives you a simple way to get the data.
https://pypi.org/project/gps3/
#!/usr/bin/python3
from gps3 import agps3
gps_socket = agps3.GPSDSocket()
data_stream = agps3.DataStream()
gps_socket.connect()
gps_socket.watch()
for new_data in gps_socket:
    if new_data:
        data_stream.unpack(new_data)
        print('Elevation = ', data_stream.alt)
        print('Latitude = ', data_stream.lat)
        print('Longitude = ', data_stream.lon)
This is a doctor free zone.
H.A
Re: sim808 and waze
Fri Jul 27, 2018 6:38 am
I've no useful data for cgps yet, even replacing gpsd with my script.
I've searched to find out communication between cgps and gpsd and found nothing useful, - because my network -.
So i have no idea about how cgps and gpsd are talking between each other- it will be useful if i have sample full communication of them ;)-
And now i have just this :
Re: sim808 and waze
Fri Jul 27, 2018 12:22 pm
gpsd has a TCP/IP socket listener. cgps is a TCP/IP socket client. It calls stuff in gpsdclient.c.
http://git.savannah.gnu.org/cgit/gpsd.g ... sdclient.c
H.A
Re: sim808 and waze
Sun Aug 05, 2018 3:54 pm
I've replace sim808 by neo6 to find out parameters, It was OK.
But i see hopping in track value
Is it ok or something goes wrong here ?
H.A
Re: sim808 and waze
Tue Aug 07, 2018 4:17 pm
Nothing ? no one can help ?
