technohead10
automatic rabbit feeder clock
Tue Jul 10, 2018 8:46 am
I was wondering how to make a timer that uses the raspberry pi zero w to feed my rabbit at a set time (say 9:00 AEDT) using motors and PBC pipes.
Notes:
It doesn't have to connect to wifi
It will always be on
Its USB port is dead
pcmanbob
Re: automatic rabbit feeder clock
Wed Jul 11, 2018 11:11 am
Hi.
if you pi is not going to be connected to the internet you will need to add a real time clock to set the time on start up, as the pi normally gets it time from the internet.
there are lots of examples of people feeding pets using a pi on the web.
some examples
http://www.instructables.com/id/Interne ... et-Feeder/
https://storiknow.com/automatic-cat-fee ... pberry-pi/
http://drstrangelove.net/2013/12/raspbe ... r-updates/
these will give you some ideas on how to go about it.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
