Is this a good relay schematic
Posted: Thu Jun 21, 2018 5:11 pm
by scheppen
Hi all,
I've just been playing with my pi zero and relayboard. I've made now this schematic. I just wanted to ask if this is a good one. Its party working in real life. When I switch the most right led on, then i'm able to turn the other ones on or off(which is a good thing :D). But the right led is only lighting up when i turn one of the left leds on. How can i solve this.
What I want is that the most right led is a sort of safety led. If this led is turned on i want to be able to switch the other ones on or off. Otherwise i dont want to be able to switch leds to the left on.
Re: Is this a good relay schematic
Posted: Thu Jun 21, 2018 8:34 pm
by pcmanbob
This is how I would wire the circuit so that the master relay controls the other 3.
Posted: Sun Jun 24, 2018 6:27 am
by scheppen
Thanks! this is what ive been looking for.
Works like a charm. Now the next step is understanding node-red :D
Posted: Sun Jun 24, 2018 8:16 am
by Z80 Refugee
Yes, but do you now understand why your original circuit didn't work? You were trying to share the current that is enough to run one LED between up to three other LEDs.
I realise it is "boring" to learn the basis of electronics before shoving anything together, but it really is necessary!
