chetuk
Help for workflow diagram logic
Tue Jun 19, 2018 4:28 pm
Please help for workflow diagram logic line follow and obstacle together.
Where robot will follow line but in case obstacle comes stop.
/Chetuk
scotty101
Re: Help for workflow diagram logic
Tue Jun 19, 2018 4:49 pm
For other posters:
Check out the OPs other topics on the same project
viewtopic.php?f=37&t=208277&p=1288974
viewtopic.php?f=37&t=174980&p=1280888
chetuk, by "workflow diagram" do you mean a flowchart?
Like this? https://en.wikipedia.org/wiki/Flowchart
B.Goode
Thu Jun 21, 2018 5:47 pm
chetuk wrote:
Thu Jun 21, 2018 5:35 pm
Yes workflow diagram
No.
A flowchart is what you seek, not a workflow diagram.
From https://www.lucidchart.com/pages/workflow-diagram
A workflow diagram (also known as a workflow) provides a graphic overview of the business process.
and
The term “workflow” is sometimes confused with other similar terms:
Flowchart: A flowchart is the actual chart that illustrates your workflow. Flowcharts are used to depict a variety of concepts, including workflows.
chetuk
Mon Jun 25, 2018 8:31 pm
Intension is to understand logic of code via diagram so that line follow and obstacle robot works.
/Chetuk
scotty101
Tue Jun 26, 2018 10:37 am
Perhaps since this is your project, you could draw your own flowchart or "workflow diagram" and then we can help you to improve it.
I made Lego Mindstorms robots with some 12 years olds which did line following and object avoidance and the best way for them to figure out the problem was to have them outside following a line of rope pretending to be robots to try to decide what decisions needed to be made, in what order and then what actions to take.
