smilliken
Contact: Twitter
Pi Powered Fan
Tue Jun 19, 2018 12:19 am
I recently followed this MagPi tutorial https://www.raspberrypi.org/magpi/pi-powered-fan/ and Wanting to know if there is any way to shut down the USB port to which the fan is connected? When I turn on the fan with the fan's switch, it runs constantly, no matter where any of the temperature settings are set.
Raspberry Pi 2 B, 7" Raspberry Pi Touchscreen
Raspberry Pi 3, PiPhat, Pi Zero W
PhatFil
Re: Pi Powered Fan
Tue Jun 19, 2018 1:03 am
Part of the setup/install is the installation of the hub-ctrl s/w which is invoked to turn on off the usb port..
https://github.com/jeroenpeters1986/piF ... _on_off.py
control_command = "sudo {}hub-ctrl -h 0 -P 2 -p {}"
complete_control_command = shlex.split(control_command.format(pifan_path, str(switch)))
subprocess.call(complete_control_command)
switch = 0 (fan off)
=1 (fan on)
so check you have that installed ok and try
[code]hub-ctrl -h
0r
hub-ctrl -man
[/code]
for help.
smilliken
Contact: Twitter
Re: Pi Powered Fan
Tue Jun 19, 2018 2:08 am
Thanks for the reply. I checked to see the files were located in the pifan directory and they are.
The snippet you showed is there in switch_on_off.py:
#!/usr/bin/python
import json
import shlex
import subprocess
import time
pifan_path = "/home/pi/pifan/"
with open("{}data/curr_threshold.json".format(pifan_path), 'r') as json_file:
    curr_threshold = float(json.load(json_file).get('temperature'))
with open("{}data/curr_temp.json".format(pifan_path), 'r') as json_file:
    curr_temp = float(json.load(json_file).get('temperature'))
# ./hub-ctrl -h 0 -P 2 -p 0
switch = 0
if curr_temp > curr_threshold:
    switch = 1
time.sleep(15)
This is take directly from the file switch_on_off.py
I ran
[email protected]:~/pifan/python $ sudo python switch_on_off.py
sudo: /home/pi/pifan/hub-ctrl: command not found
smilliken
Contact: Twitter
Re: Pi Powered Fan
Tue Jun 19, 2018 2:41 am
The file hub-ctrl is there, just needed to change the permissions for execution. Did that, now the Pi hangs on boot.
smilliken
Contact: Twitter
Re: Pi Powered Fan
Tue Jun 19, 2018 9:42 pm
Starting back from scratch, re-installing the image and will go back thru the installation of the software on the blog page.
Strange.
PhatFil
Re: Pi Powered Fan
Wed Jun 20, 2018 12:08 am
googleing hub-ctrl found the projects github page. perhaps try cloning installing the prerequisite libsub-dev and compiling the source as suggested in the readme to test ?
https://github.com/codazoda/hub-ctrl.c
Z80 Refugee
Re: Pi Powered Fan
Wed Jun 20, 2018 9:06 am
I don't get it. Aren't you guys missing something obvious?
A standard "USB Fan" is only USB powered, not USB controlled. I can't see anything here which is able to turn the fan on or off by program control, because all you actually have is a 5V fan running off the power from a constantly-powered USB port.
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
smilliken
Contact: Twitter
Re: Pi Powered Fan
Wed Jun 20, 2018 2:23 pm
As you are probably right, why then, does the project portrait the fan will turn on and off.. Hence the "clever code and a USB fan, you’ll be able to keep your cool" statement.
I don't know all of the inner workings of USB, but I'm willing to learn.
Z80 Refugee
Re: Pi Powered Fan
Wed Jun 20, 2018 2:37 pm
I don't have an answer to that one - maybe you should put a query in the discussion area for that MagPi article. I hesitate to say it, but it looks like a scam to me.
A USB connector has a supply of 5V, handy for powering accessories on the desktop (the real one) because most desks have a computer and therefore a USB port. There are lots of toys that make use of 5V from a USB port, and some that have interface electronics and can be controlled from an app (eg robot arm, missile launcher...). A fan just needs 5V. On the RPi, the USB 5V is simply connected to the input 5V, so is always on (as long as the RPi is powered).
The only way that article makes sense is if they have acquired a fan that has some built-in control electronics that can be commanded by the USB data line. As far as I can see, that is not mentioned. Just any old USB fan won't do.
What you need to do with a normal, simple, 5V fan, is use a GPIO line and a transistor or relay to turn it on/off. There are plenty of examples on this forum, eg viewtopic.php?f=45&t=213994
pcmanbob
Re: Pi Powered Fan
Wed Jun 20, 2018 2:58 pm
I think what the code is supposed to do is turn off the 5v to the USB ports, I know this is possible but I am not sure its the same for all pi models.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Z80 Refugee
Re: Pi Powered Fan
Wed Jun 20, 2018 3:53 pm
Is it? Since when? Please refer me to something that says so, and then I'll eat my hat.
smilliken
Contact: Twitter
Re: Pi Powered Fan
Wed Jun 20, 2018 6:23 pm
I did drop a couple questions in the comments, but there has been no replies. Thus the reason I post here.
pcmanbob
Re: Pi Powered Fan
Wed Jun 20, 2018 7:38 pm
Hope you like hats.
viewtopic.php?t=93463
https://lb.raspberrypi.org/forums/viewt ... p?t=162539
https://raspberrypi.stackexchange.com/q ... -on-a-pi-3
https://gist.github.com/hfreire/32deb6b ... 8954e954fe
https://github.com/SkyJohn/Homebridge-R ... er-Control
PhatFil
Re: Pi Powered Fan
Wed Jun 20, 2018 8:20 pm
My first reaction too but then i chased down the link and found the hub-ctrl project..
smilliken
Contact: Twitter
Re: Pi Powered Fan
Wed Jun 20, 2018 11:53 pm
Hope you like hats.
So in each of the links noted above, it shown the power can be stopped to the USB. Now, is this to a specific port or to the hub? If it is the hub, and one has a wifi dongle, then it will be dead too. have to wait until it gets hot to use the wifi!
Z80 Refugee
Re: Pi Powered Fan
Thu Jun 21, 2018 7:38 am
Wow! (proxy for something more colourful) Thanks for that. I made the mistake of trusting the published schematics and did not spot they were incomplete - so actually they are not worth the paper they are printed on. :x
Let the hat fest commence...
pcmanbob
Re: Pi Powered Fan
Thu Jun 21, 2018 8:39 am
Hope you like hats.
You can only turn off all the USB ports and the LAN chip using these mothods, there is no way to switch individual USB ports off.
smilliken
Contact: Twitter
Re: Pi Powered Fan
Thu Jun 21, 2018 10:27 pm
Thanks, that's what I thought. No good if you require any other USB device to work.
PhatFil
Re: Pi Powered Fan
Fri Jun 22, 2018 7:33 am
Control USB power on a port by port basis on some USB hubs.
first line in the readme of the ctrl-hub project..
seems to me that its quite an easy test to clone/download the project and its prerequisite and compile it on your pi for a suck n see test..
sourcing a compatible hub is an option too
D-Link-DUB-H7-High-Speed-7-Port (Tested with old Silver versions (A3, A4 & A5). Also tested with newer Black version C1).
Elecom: U2H-G4S
Sanwa Supply: USB-HUB14GPH
Targus, Inc.: PAUH212
Hawking Technology: UH214
B&B Electronics: UHR204
Belkin: F5U701
Linksys: USB2HUB4
Z80 Refugee
Re: Pi Powered Fan
Fri Jun 22, 2018 7:51 am
Nonetheless, it is interesting to know projects (that don't need USB) have a source of switchable 5V power. That could be used for a low-power standby mode, or even direct drive for a relay coil. Excellent. Now to find a way to access it in Forth...
jeroenpeters
Re: Pi Powered Fan
Mon Jul 30, 2018 7:34 am
Hi all, I'm the author of that article, but I had no idea it was discussed here. I see the questions are already answered, but nevertheless I signed up and am now subscribed to the topic. So if there are any further questions, I'd like to (try and) answer them :-)
My first Pi appliance was only to keep my head cool and it needed no USB Wifi or a keyboard. In the meantime, it evolved to a Pi3 and has a hacky python script which logs the temperature to Google Spreadsheet :-)
EqualDemo
Re: Pi Powered Fan
Fri Aug 10, 2018 12:16 am
So I just "completed" this project and got the interface loaded up. The problem is, the fan will not stop running. I'm not sure what I need to do now.
I did load this on a Raspberry Pi with Raspbian running, which I've run a bunch of other projects on. I'm not sure if that is affecting the fan not stopping.
Thanks for any help.
jeroenpeters
Re: Pi Powered Fan
Fri Aug 10, 2018 4:15 pm
Hi, do your other project also run at the same time?
Can you tell me what it's outputting if you login to the Pi and then run
sudo supervisorctl status
Kind regards, Jeroen
smilliken
Contact: Twitter
Re: Pi Powered Fan
Sat Aug 11, 2018 1:48 am
this is not for me, but I ran the command and it advised me the command was not found.
jeroenpeters
Re: Pi Powered Fan
Sat Aug 11, 2018 8:23 am
Hi Smiliken,
thanks for replying, have you followed the installation instructions from the magazine? There is also a digital post on the Magpi from this, it's on https://www.raspberrypi.org/magpi/pi-powered-fan/
There is one small, but important, line which states:
sudo apt-get install nginx-light supervisor git build-essential python-dev python-pip
This is needed to install supervisor, can you try this again and if it gives any errors, can you post them here?
