thomasdanz
High-Precision AD/DA Board + Raspberry PI3
Sat Jun 16, 2018 11:06 pm
Hello guys, i want to use this analog-digital board to convert analog signals from soil moisture sensor to digital and
concume it in my nodejs script.
  1. Sensor: https://www.dfrobot.com/product-1385.html
  2. ADC board: https://www.waveshare.com/w/upload/b/b7 ... Manual.pdf
  3. Raspberry Pi3
So my problem is next: i inserted extension board on top of Raspberry and installed library as
explained in user manual but executing test code
returns next:
ADS1256_WaitDRDY() Time Out ...
ID=
Error, ASD1256 Chip ID = 0x0
I think Chip ID must be assigned to some address, so having that in 0x0 makes test fail.
Also i have a little experience with sensor ( before i've used digital only) so in general don't understand where from i should read
converted signal, given that i connect sensor to VCC, GND and AD0 on left side of extension board.
Can someone help me out please?
Idahowalker
Re: High-Precision AD/DA Board + Raspberry PI3
Sun Jun 17, 2018 4:42 pm
Is the chip an I2C or a SPI bus chip?
Have you did a google search on enabling the I2C or SPI bus on a Raspberry Pi and followed the instructions to enable I2C or SPI?
Have you set the address, if needed, of the Analog to Digital converter module?
It might behoove you to write down, say the I2C, address in use before plugging the A to D converter into the RPi. That way you can note the address in use and note the new address that shows up with the addition of the A to D or, if no new address shows up, know there might be a conflicting device on the bus.
Without knowing why you are deleting my postings, I will not know how...
thomasdanz
Sun Jun 17, 2018 6:40 pm
1) In Features section of manual it says that chip is ADS1256
which googles to this from here i can say that chip is SPI.
2) To enable SPI interface, as i'm using dietpi distro i edited a
/DietPi/config.txt
with this and rebooted.
#-------spi-------------
dtparam=spi=on
3) Executed lsmod
lsmod | grep spi
spidev                 16384  0
spi_bcm2835            16384  0
4) executed test from as i've mentioned in first post but still no avail
alexhackney
Wed Aug 29, 2018 10:55 am
Did you get this figured out? I want to read the output of an audio source to determine if it is at a certain level or not then perform a function based on that. I'm really struggling with this lol.
Brandon92
Thu Aug 30, 2018 7:24 pm
Can you provide a more information. We can't help you if you don't provide us any kind of (technical / software) information about you setup. Because you have already something, but it doesn't work?
For example some questions for you:
- How did you connect the (AC) audio to the input?
- What is the audio source?
- What do you have now?
thomasdanz
Wed Sep 12, 2018 2:11 pm
Hi All, sorry for a late response, i got it working with this library
https://github.com/ul-gh/PiPyADC
thaslima
Thu Oct 25, 2018 1:59 am
hi where did you get the library for the ADC
DirkS
Thu Oct 25, 2018 8:19 am
See the post above yours where OP says
thaslima
Mon Oct 29, 2018 9:49 am
hi
i have assigned to do a project with
A pulse sensor https://pulsesensor.com/
Raspberry Pi3 b+
can someone guide me on how to read the data from the sensor
