njp83
Using a Yocto-volt sensor on a Raspberry pi
Fri Jun 15, 2018 4:18 am
Hi, sorry but new to all this. I am trying to get a yoctopuce volt senor to work on my rpi. when i try run a program from a list of there example the error below comes up.
Any help would be greatly apprieciated
Regards Nathan
File "genprog1", line 7, in <module>
from yocto_api import *
ImportError: No module named yocto_api
pcmanbob
Re: Using a Yocto-volt sensor on a Raspberry pi
Fri Jun 15, 2018 3:18 pm
HI.
You have not really give us any information to go on.
but from the error message I would say you have not installed the yocto_api module.
if you want more detailed help you need to provide details for the project web page you are following and what mode of pi you are using along with which OS you have installed as a starting point.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
yoctopuce
Sun Jun 17, 2018 5:02 am
Chances are that you did not install the Yoctopuce python library properly. You should read that page:
www.yoctopuce.com/EN/article/for-the-be ... ce-modules
Don't hesitate to contact Yoctopuce support directly if you need more help.
We produce USB controllers, USB sensors as well as embedded USB hubs for DIY projects
njp83
Sun Jun 24, 2018 11:31 pm
Thanks, that fixed that issue, I didn't install the library where it could be found.
Regards Nathan
