blazbrajer
temp sensor ds18b20 problems
Tue May 15, 2018 10:57 am
I have problem with reading sensor and temp. When i connect 20 sensors, i get one or none active sensor. Max sensors then it works is 15.
i use temp sensors ds18b20, the maximum distance from the sensor to the rpi is 10m.
thanks for the help :)
Ferdinand
Re: temp sensor ds18b20 problems
Tue May 15, 2018 3:06 pm
Hi blazbrajer,
A good starting point is:
https://www.maximintegrated.com/en/app- ... mvp/id/148
Success with your project!
Ferdinand
bensimmo
Tue May 15, 2018 4:01 pm
Is that all off one gpio pin or are you using multiple gpio pins.
You may need to boost voltages for longer distances.
blazbrajer
Thu May 17, 2018 7:17 am
hi bensimmo
all sensor are connected to one gpio
i was thinkig to simulate another w1 pin and devide sensors to 10/10
hi Ferdinand
I found that the problem is in star topology. Tnx for help and article :)
bensimmo
Thu May 17, 2018 8:03 am
try adding them to another gpio pin and enabling 1-wire on that.
blazbrajer
Thu May 17, 2018 12:57 pm
do u have any code or script to simulate another w1 on other pin? i was searching all day and i didnt found anything :(
B.Goode
Thu May 17, 2018 2:21 pm
At the moment I can't find a definitive answer from the Raspberry Pi Foundation documentation either.
But this link appears to provide the basic details you need to know: https://pinout.xyz/pinout/1_wire
bensimmo
Thu May 17, 2018 2:40 pm
Argh just lost my last post :-(
Anyway as above
dtoverlay=w1-gpio,gpiopin=4
dtoverlay=w1-gpio,gpiopin=21
etc
Replacing the current w1-gpio line in /boot/config.txt
There is a longish topic in the depths of the forum that includes when these lines where added, iirc it came about from using a different gpio from default.
blazbrajer
Fri May 18, 2018 6:27 am
thank you all for the help :D :D
