I have read countless forum posts, and spent hours trying to figure this out and cannot seem to get my DH22 AM2302 temperature/humidity sensor to work. Can someone familiar with this please have a look at my setup? I must be missing something simple? I have tried two different sensors thinking one was damaged.
Here is my connections:https://imagebin.ca/v/3yl8DleaaQ1Y
--I followed the adafruit tutorial (several times) and have run the example code "simpletest.py" and am getting the printout "'Failed to get reading. Try again!"
#!/usr/bin/python
# Copyright (c) 2014 Adafruit Industries
# Author: Tony DiCola
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import Adafruit_DHT
# Sensor should be set to Adafruit_DHT.DHT11,
# Adafruit_DHT.DHT22, or Adafruit_DHT.AM2302.
sensor = Adafruit_DHT.2302
# Example using a Beaglebone Black with DHT sensor
# connected to pin P8_11.
#pin = 'P8_11'
# Example using a Raspberry Pi with DHT sensor
# connected to GPIO23.
pin = 4
# Try to grab a sensor reading. Use the read_retry method which will retry up
# to 15 times to get a sensor reading (waiting 2 seconds between each retry).
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
# Note that sometimes you won't get a reading and
# the results will be null (because Linux can't
# guarantee the timing of calls to read the sensor).
# If this happens try again!
if humidity is not None and temperature is not None:
print('Temp={0:0.1f}*C Humidity={1:0.1f}%'.format(temperature, humidity))
else:
print('Failed to get reading. Try again!')Code: Select all
#!/usr/bin/env python
# 2014-07-11 DHT22.py
import time
import atexit
import pigpio
class sensor:
A class to read relative humidity and temperature from the
DHT22 sensor. The sensor is also known as the AM2302.
The sensor can be powered from the Pi 3V3 or the Pi 5V rail.
Powering from the 3V3 rail is simpler and safer. You may need
to power from 5V if the sensor is connected via a long cable.
For 3V3 operation connect pin 1 to 3V3 and pin 4 to ground.
Connect pin 2 to a gpio.
For 5V operation connect pin 1 to 5V and pin 4 to ground.
The following pin 2 connection works for me. Use at YOUR OWN RISK.
5V--5K_resistor--+--10K_resistor--Ground
DHT22 pin 2 -----+
gpio ------------+
def __init__(self, pi, gpio, LED=None, power=None):
Instantiate with the Pi and gpio to which the DHT22 output
pin is connected.
Optionally a LED may be specified. This will be blinked for
each successful reading.
Optionally a gpio used to power the sensor may be specified.
This gpio will be set high to power the sensor. If the sensor
locks it will be power cycled to restart the readings.
Taking readings more often than about once every two seconds will
eventually cause the DHT22 to hang. A 3 second interval seems OK.
self.pi = pi
self.gpio = gpio
self.LED = LED
self.power = power
if power is not None:
pi.write(power, 1) # Switch sensor on.
time.sleep(2)
self.powered = True
self.cb = None
atexit.register(self.cancel)
self.bad_CS = 0 # Bad checksum count.
self.bad_SM = 0 # Short message count.
self.bad_MM = 0 # Missing message count.
self.bad_SR = 0 # Sensor reset count.
# Power cycle if timeout > MAX_TIMEOUTS.
self.no_response = 0
self.MAX_NO_RESPONSE = 2
self.rhum = -999
self.temp = -999
self.tov = None
self.high_tick = 0
self.bit = 40
pi.set_pull_up_down(gpio, pigpio.PUD_OFF)
pi.set_watchdog(gpio, 0) # Kill any watchdogs.
self.cb = pi.callback(gpio, pigpio.EITHER_EDGE, self._cb)
def _cb(self, gpio, level, tick):
Accumulate the 40 data bits. Format into 5 bytes, humidity high,
humidity low, temperature high, temperature low, checksum.
diff = pigpio.tickDiff(self.high_tick, tick)
if level == 0:
# Edge length determines if bit is 1 or 0.
if diff >= 50:
val = 1
if diff >= 200: # Bad bit?
self.CS = 256 # Force bad checksum.
else:
val = 0
if self.bit >= 40: # Message complete.
self.bit = 40
elif self.bit >= 32: # In checksum byte.
self.CS = (self.CS<<1) + val
if self.bit == 39:
# 40th bit received.
self.pi.set_watchdog(self.gpio, 0)
total = self.hH + self.hL + self.tH + self.tL
if (total & 255) == self.CS: # Is checksum ok?
self.rhum = ((self.hH<<8) + self.hL) * 0.1
if self.tH & 128: # Negative temperature.
mult = -0.1
self.tH = self.tH & 127
else:
mult = 0.1
self.temp = ((self.tH<<8) + self.tL) * mult
self.tov = time.time()
if self.LED is not None:
self.pi.write(self.LED, 0)
else:
self.bad_CS += 1
elif self.bit >=24: # in temp low byte
self.tL = (self.tL<<1) + val
elif self.bit >=16: # in temp high byte
self.tH = (self.tH<<1) + val
elif self.bit >= 8: # in humidity low byte
self.hL = (self.hL<<1) + val
elif self.bit >= 0: # in humidity high byte
self.hH = (self.hH<<1) + val
else: # header bits
pass
self.bit += 1
elif level == 1:
self.high_tick = tick
if diff > 250000:
self.bit = -2
self.hH = 0
self.hL = 0
self.tH = 0
self.tL = 0
self.CS = 0
else: # level == pigpio.TIMEOUT:
if self.bit < 8: # Too few data bits received.
self.bad_MM += 1 # Bump missing message count.
self.no_response += 1
if self.no_response > self.MAX_NO_RESPONSE:
self.bad_SR += 1 # Bump sensor reset count.
if self.power is not None:
self.powered = False
self.pi.write(self.power, 0)
time.sleep(2)
self.pi.write(self.power, 1)
time.sleep(2)
self.powered = True
elif self.bit < 39: # Short message receieved.
self.bad_SM += 1 # Bump short message count.
else: # Full message received.
def temperature(self):
"""Return current temperature."""
return self.temp
def humidity(self):
"""Return current relative humidity."""
return self.rhum
def staleness(self):
"""Return time since measurement made."""
if self.tov is not None:
return time.time() - self.tov
else:
return -999
def bad_checksum(self):
"""Return count of messages received with bad checksums."""
return self.bad_CS
def short_message(self):
"""Return count of short messages."""
return self.bad_SM
def missing_message(self):
"""Return count of missing messages."""
return self.bad_MM
def sensor_resets(self):
"""Return count of power cycles because of sensor hangs."""
return self.bad_SR
def trigger(self):
"""Trigger a new relative humidity and temperature reading."""
if self.powered:
self.pi.write(self.LED, 1)
self.pi.write(self.gpio, pigpio.LOW)
time.sleep(0.017) # 17 ms
self.pi.set_mode(self.gpio, pigpio.INPUT)
self.pi.set_watchdog(self.gpio, 200)
def cancel(self):
"""Cancel the DHT22 sensor."""
if self.cb != None:
self.cb.cancel()
self.cb = None
if __name__ == "__main__":
import time
import pigpio
import DHT22
# Intervals of about 2 seconds or less will eventually hang the DHT22.
INTERVAL=3
pi = pigpio.pi()
s = DHT22.sensor(pi, 4, LED=16, power=8)
r = 0
next_reading = time.time()
while True:
r += 1
s.trigger()
time.sleep(0.2)
print("{} {} {} {:3.2f} {} {} {} {}".format(
r, s.humidity(), s.temperature(), s.staleness(),
s.bad_checksum(), s.short_message(), s.missing_message(),
s.sensor_resets()))
next_reading += INTERVAL
time.sleep(next_reading-time.time()) # Overall INTERVAL second polling.
s.cancel()
pi.stop()
I am ready to give up, but thought I would see if someone has had similar issues.
Lastly, is there a sensor that is a little more user (inexperienced user) friendly for the raspberry pi?
Any help is appreciated!
Thanks!
