sony8943
bluetooth proximity car
Mon Apr 16, 2018 4:38 pm
#!/usr/bin/python
import bluetooth
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
RELAY = 17
GPIO.setup(RELAY, GPIO.OUT)
while True:
    print "Checking " + time.strftime("%a, %d %b %Y %H:%M:%S",
time.gmtime())
    result = bluetooth.lookup_name('78:7F:70:38:51:1B', timeout=5)
    if (result != None):
        print "User present"
        GPIO.output(RELAY,1)
    else:
        print "User out of range"
        GPIO.output(RELAY,0)
    time.sleep(10)
Hello world i find this code on internet github and i its working fine the led is turn on when you have bluetooth on and the led is turn off when bluetooth is off
this project i want to instal in my car i have a switch for lock and unlock the doors : the problem is i have to give signal for 1 or 2 sec ( pin 17 led stay on for 2 sec when bluetooth is on) and (pin 18 led stay on for 2 sec when bluetooth is off , of course i have to put another pin gpio 18 or another pin
how to insert in code this pin 17 to stay 2 sec when bluetooth is on and
pin 18 to stay 2 sec when bluetooth is off
thankyou
pcmanbob
Re: bluetooth proximity car
Tue Apr 17, 2018 7:07 am
Hi.
Adding the extra relay operation is as simple as specifying a new output and then adding the 2 outputs and a sleep command to the if and else parts of the code, like this
#!/usr/bin/python
import bluetooth
import time
locked = 17
unlocked = 18
GPIO.setup(locked, GPIO.OUT)
GPIO.setup(unlocked, GPIO.OUT)
while True:
time.gmtime())
        GPIO.output(unlocked,1)
        time.sleep(2)
        GPIO.output(unlocked,0)
    else:
        GPIO.output(locked,1)
        time.sleep(2)
        GPIO.output(locked,0)
    time.sleep(10)
untested code there may be errors
you have not said if your relay is active high or active low, so I assumed active high but you can change this if need be.
also as the code stands the relays will continue to be activated every 10 seconds on each execution of the while loop, to prevent this you will need to add some logic code so your relays only operate once for locking and unlocking..
sony8943
Tue Apr 17, 2018 3:53 pm
thanks pcmanbob i check i connect 2 led on in pin 17 one in pin 18 its working very good ;but is stay 2 sec open after 10 sec off just i need once to give 2 sec and stay off forever; so i need to find a timer push button to pres continuu ( or switch) and give 2 sec signal to another gpio pin
pcmanbob
Tue Apr 17, 2018 4:08 pm
What you need is to add some logic to the python program so that once a relay has been activated it will not activate again until the other has been activated.
some thing like this
#!/usr/bin/python
import bluetooth
import time
locked = 17
unlocked = 18
rls = 0
ruls = 0
while True:
time.gmtime())
        if ruls = 0:
            time.sleep(2)
            ruls = 1
            rls = 0
    else:
        if rls = 0
            time.sleep(2)
            rls = 1
            ruls = 0
    time.sleep(10)
untested code
sony8943
Tue Apr 17, 2018 4:43 pm
i try but is not working
proximity bluetooth car.jpg (224.6 KiB) Viewed 1280 times
Tue Apr 17, 2018 7:11 pm
Change
        if ruls = 0:
to
        if ruls == 0:
pcmanbob
Tue Apr 17, 2018 7:56 pm
Yes there were several errors in my code but I did say it was untested.
so here is the corrected code
#!/usr/bin/python
import bluetooth
import time
locked = 17
unlocked = 18
rls = 0
ruls = 0
while True:
time.gmtime())
        if ruls == 0:
            time.sleep(2)
            ruls = 1
            rls = 0
    else:
        if rls == 0:
            time.sleep(2)
            rls = 1
            ruls = 0
    time.sleep(10)
sony8943
Wed Apr 18, 2018 5:38 am
thank you a lot its working fine
i am not connect relay, only 2 pnp transistor bd 138 and i try to find this python script to run automatic when i open raspberry pi with schedule program ( 22:00 to 4:00 the program will shout off) and day is (4:10 to 21:50)
sony8943
Wed Apr 18, 2018 8:11 am
and how to add extra address bluetooth
pcmanbob
Wed Apr 18, 2018 2:15 pm
if your pi is running 24/7 your can start the program using cron so that it will start at 4:10 , to stop it you will need to do that within the program, say after a set amount of time has passed.
what have you tired to add a second Bluetooth address.
