Mastermime
Using the Raspberry Pi as a Controller System
Sun Oct 14, 2012 7:54 pm
Hello everyone,
I am designing a controller system for my search and rescue robot. I'll start off by stating the requirements:
- Robot controlled by Logitech joystickhttp://www.logitech.com/en-us/gaming/jo ... eme-3d-pro
- Servo control for panning camera
- Directional control (forward, backward, turn left, turn right)
- Turn LEDs On/Off
- Turn motors off (relay on robot connected to 5v signal to keep activated, when there is no signal, the motors shut off)
- Live video display on LCD (from Video Receiver)
- Output of sensor results from robot ie temperature sensors, battery level (voltage divider connected ADC on Axon II)
- Xbee data transceiver (simple serial)
Would it be possible to use a Raspberry Pi to process the joystick commands and send them through the Xbee and output the sensor results on the LCD?
ghans
Re: Using the Raspberry Pi as a Controller System
Thu Oct 18, 2012 7:59 pm
Possible , but how much electronics and programming experience do you have ?
This will need loads of both. And perhaps add a Arduino/microcontroller .
ghans
Mastermime
Fri Oct 19, 2012 2:43 am
I am experienced with electronics, but I am not experienced with programming. Would it just be easier to use a different board other than the Raspberry Pi?
ghans
Fri Oct 19, 2012 10:40 am
Perhaps a Arduino would be enough ?
Better ask in their own forums. Both Pi and Arduino are simple to program ,
i do not think that there are boards for your purpose which would be simpler.
ghans
eyebee
Sun Oct 21, 2012 4:56 am
You should be able to do all that with the Pi. I am not sure about your particular model of joystick but its easy enough to test.
If you are running wheezy you can install the jstest utility:
sudo apt-get install joystick
and then run jstest:
jstest /dev/input/js0
I just dug out a 10 year old Logitech wireless joystick (Freedom 2.4) and it worked just fine (once I cleaned off the corroded battery contacts, lol)
Lots of people are experimenting with Pis and Xbees. If you google around you should be able to find lots of info.
http://lookmanowire.blogspot.de/2012/07 ... -xbee.html
http://www.bootc.net/archives/2012/07/2 ... xbee-pcbs/
http://www.cooking-hacks.com/index.php/ ... ry-pi-xbee
As a programming beginner, you might find it much easier to program in Python on the Pi than to deal with C on the Arduino.
ToddFerrante
Mon Oct 22, 2012 1:08 pm
I'm working on developing a similar system. You can see my current status in this thread: http://www.raspberrypi.org/phpBB3/viewt ... 37&t=19939
My goal is to minimize non-Pi hardware if at all possible. So far, I haven't needed to use any more boards (like the Arduino, Gertboard, or adafruit PWM board) by sticking to PWM control of RC style reversible brushed motor drivers. If I do add any more hardware, it will be the least expensive stuff that will do the job. I particularly like the adafruit board because it is low cost, runs lots of PWM outputs, and frees up lots of the Pi GPIO pins for other IO tasks.
Todd F.
