nsuser
Measuring strength of vibration from sensor in python. C Code provided!
Thu Dec 14, 2017 3:09 am
Measuring the strength of vibration (length of the pulse) and raw data from a sensor breakout is provided below in C:
http://www.theorycircuit.com/sw-420-vib ... interface/
How can the same be done in python?
nsuser
Re: Measuring strength of vibration from sensor in python. C Code provided!
Thu Dec 14, 2017 2:19 pm
But, this would still just give the HIGH vs LOW. I have that already. I am looking f0r the strength of the pulse with the numbers.
Is that correct?
supra wrote:
Thu Dec 14, 2017 1:41 pm
I do not test this. Because I don't have vibration.
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
vibr_pin = 8
LED_Pin = 10
GPIO.setup(channel, GPIO.IN)
GPIO.setup(channel, GPIO.OUT)
while True:
    val = 0
    val = input(vibr_pin)
    if(val==1):
        GPIO.output(LED_Pin, GPIO.HIGH)
        sleep(1000)
        GPIO.output(LED_Pin, GPIO.LOW)
        sleep(1000)
    else:
GPIO.cleanup()
pcmanbob
Thu Dec 14, 2017 3:33 pm
But if that is all you sensor outputs then that's all you can get from it, just because you found some code to do some thing else does not mean your sensor can do it.
if your sensor was capable of sending data over a serial interface then I would expect it to have a serial out pin at least and probably more likely TXD and RXD pins to allow serial communication.
if you are still using the SW-420 vibration sensor that you are asking about in your other posts then it just outputs high or low, there is no mention of serial data output.
henmina53
Wed Jul 04, 2018 5:04 am
Well as per your subject line, I am on working on something similar with wireless vibration sensor https://store.ncd.io/product/iot-long-r ... re-sensor/ which shares much precised values of vibration on machines,fans, washing machine and many other appliances,
You may have look on manual also they have given the code in arduino also, Have a look on it you might find it interesting and helpful.
