Dick Fagan
Listen into serial communication between sensor and PC
Tue Dec 12, 2017 2:49 pm
I am working on a project measuring several parameters, which needs to be synchronized with a computer. The PC is already getting its position and exact time via a GPS device (Garmin GPS19x HVS) over the NMEA 0182 standard which is currently running over an RS-422 connection. My plan is to listen to this communication with the Raspberry Pi (with Raspbian) without interfering with it.
My problems are:
1) Hardware:
Can I simply create a 'T' connection from the Tx and Rx lines to the Raspberry Pi, or do I need to seperate the Raspberry Pi (e.g. with optocouplers) in order not to interfere? I am using an 8 port serial to usb adapter with the Raspberry.
2) Software:
Until now I only used the Serial Python library with:
raw_data = ser.read(ser.inWaiting())
with
ser
as the serial port. But that way, everytime I read the data, I empty the buffer of the GPS and the PC can´t get the same data anymore. All I would need, is to 'spy' on the communication.
I know I could connect the Raspi to the PC and synchronize the clock that way and send the GPS position, but as the PC is part of a seperate measuring device that someone created once with LabView, I am trying to avoid having another Python skript running on there.
If anybody has an idea how to solve it,
Thank You!
J.
pbreneman
Re: Listen into serial communication between sensor and PC
Wed Dec 13, 2017 5:33 pm
Thank You!
There are several notes on the bottom example on this page:
http://ctrlterm.com/custom.htm
joan
Wed Dec 13, 2017 5:39 pm
You should be able to passively sniff the TX/RX traffic provided it is 19.2k baud or less.
See http://abyz.me.uk/rpi/pigpio/pigs.html#SLRO and http://abyz.me.uk/rpi/pigpio/pigs.html#SLR
Who is online
Users browsing this forum: descoward and 15 guests
