billings98
Hall Effect Sensor not Reading Fast Enough
Mon Nov 27, 2017 5:10 pm
I recently have been working on a school project to read rpm speeds from several different locations on a Baja vehicle. I am using a raspberry pi zero w and am running the code through python. During my recent test I noticed that most of my sensors were working and reading accurately except for one. I have one sensor reading the output of a 3600 rpm engine, and the program was maxing right around 3000 rpm. When I tested with a separate commercial gauge the engine was in fact turning at 3600. the Hall effect sensor has a working refresh rate of 10 khz so I don't think the sensor is my problem but more likely either a setting on my raspberry pi or the coding. If I need to upload the coding I can do so but I'm thinking its something like a refresh setting on the raspberry pi. Thank you.
Ronaldlees
Re: Hall Effect Sensor not Reading Fast Enough
Tue Nov 28, 2017 10:27 pm
Perhaps this thread could shed some light:
viewtopic.php?t=26907
It seems the faster sample programs are using finely tuned assembler.
I am the Umbrella man
joan
Tue Nov 28, 2017 10:42 pm
It sounds like a coding problem. I've used Hall effect sensors to measure in excess of 9000 RPM (the sensors were being pulsed in excess of 18000 RPM).
See viewtopic.php?f=37&t=90243
