Katianie
Good Robot Arm and/or Hand.
Thu Nov 23, 2017 8:25 am
I've been looking on amazon for diffrent robot arms like this:
https://www.amazon.com/dp/B074T8SKVR/
or this:
https://www.amazon.com/dp/B01FM0KKCA/
But they all have terrible reviews, none of them on amazon are above 2.5stars. Any thoughts?
OutoftheBOTS
Re: Good Robot Arm and/or Hand.
Thu Nov 23, 2017 8:30 am
You might think about building your own :) it will be fun
Katianie
Fri Nov 24, 2017 1:05 am
No, I'd rather buy a good one. I have the money for a good one if one exists.
Katianie
Wed Dec 13, 2017 9:01 pm
Bump
Chris D
Fri Dec 15, 2017 4:29 pm
I have not seen anything readily available on the market that I would say is good.
However, if you have or know someone with a 3D printer, there are a number of very impressive designs on Thingiverse. Of course it would require a substantial amount of work to get it working, but those are about the best I have seen. In a small desktop size range, there isn't going to be anything I would consider really good as in high precision, accurate motion, repeatable motion, etc. These size robot arms run on small R/C servo motors which due to their intended purpose do not have very high resolution.
Chris D
gjs31
Sat Dec 16, 2017 6:07 am
I'm looking at getting one of these: https://www.littlebirdelectronics.com.a ... controller for a rover I'm slowly working on.
Any thoughts on whether it would be possible to remove the arm from the setup and drive it off a servo board? I had a quick look at one in store and from what I can tell its just a simple set of servos driving it.
Katianie
Sun Dec 17, 2017 7:02 am
Yea that one looks good and sturdy. I'd like to know if it is possible too.
gjs31
Tue Dec 19, 2017 8:56 am
I found it in a store and it looks like the joints are driven by dc motors. Wouldn’t even know where to start controlling with those as opposed to servos.
hippy
Tue Dec 19, 2017 7:27 pm
I wouldn't bet on it. Most reviews I have seen describe thesetype of arms as "toys" though they likely have some utility. It seems Maplins in the UK are currently selling them discounted at £30 ...
https://www.maplin.co.uk/p/usb-controll ... -kit-a37jn
I had a play with a similar version which was manually controlled, perhaps a bit smaller than that, and it was extremely 'wobbly' in construction.
What exactly is your budget ?
I would guess this is one case where it is likely the more you pay the better quality one gets -
https://www.robotshop.com/uk/robotic-arms.html
asandford
Wed Dec 20, 2017 12:53 am
Apparently good one, but not in my budget to test.
Who is online
Users browsing this forum: No registered users and 22 guests
