davka003
Tellstick and more automation
Wed Oct 10, 2012 7:09 pm
Hi
If anyone is interested I have a project for home automation using Tellstick/Tellstick DUO from the swedish company Telldus Technologies. (http://telldus.com). This controls various light switches on the 433 MHz band. My favorites from Nexa but others are supported as well.
Compability list here: http://telldus.com/products/compability
Apart from commanding and getting sensor input from the above the system can also send Wake-On-Lan commands or HTTP-requests that might include the sensor values or just as a side effect when turning on or off lamps. There is also undocumented functionality to send and trigger on HDMI-CEC commands so you can turn on/off your CEC-compatible TV.
There is a very generic architecture where everything is devices, so a group can contain any number of devices including other groups.
Everything is controlled and configured thru a web page. No need to do any scripts/ssh etc. Some basic REST-API exist as well.
The system is distributed as an SD-image file (havent had time to put togheter an installation instruction). For more information visit my project home page here:
http://automagically.weebly.com/
large
Re: Tellstick and more automation
Tue Dec 18, 2012 6:55 pm
Hi David!
I've just got the Rasp and I've got alot of Nexa units around the house.
Great work on the remote, looking forward checking your stuff out! :)
Cheerio,
Lars Werner
http://lars.werner.no
seymourmj
Fri Feb 08, 2013 1:57 pm
Look forward to giving it a go. I had a make shift system going with a RF transmitter and an Arduino, after decoding all the frequencies (with a little help from the internet). But this looks a lot cleaner. Tellstick looks like a great product and saves me re-inventing the wheel.
Any chance of seeing some screenshots from the Web interface? or some description of how it works technically, just out of interest more than anything else. If I get it up and running I'll drop a donation your way for sure.
Matt
davka003
Sat Feb 09, 2013 12:14 pm
Hi
The control interface have some screenshots here:
http://automagically.weebly.com/1/post/ ... -page.html
And there are some rather old screenshot here:
http://automagically.weebly.com/1/post/ ... image.html
(The control page shown here is still available but the one linked above is the "good looking one")
Basically the system consist of a Apache2 webserver running django. This presents all the user interface and provide configuration of the system as well as having a REST-API for making commands and query the status of the system.
There is also a daemon that works in the background that sends out actuall commands to the Tellstick/Wake-on-lan/http requests as well as gaterhering information from various sources. These run in a system with plugins that makes it easy to write a custom python module for interacting with something else.
Everything written in Python by me personally except for one plugin for 1-wire that is contributed by a user.
If there is anything more you want to know, please ask.
freedomotic
Sun Feb 10, 2013 4:34 pm
your project is very interesting and promising.
We are working on an open source domotic framework.
If you want you could develop a plugin to control your tellstick devices using our software freedomotic.
By this way you can communicate with other tecnologies, creates automations and so on.
Take a look at freedomotic.com .
Anyway good work!!!
Regards
Freedomotic Open IoT Framework
http://freedomotic.com
jets
Tue Oct 29, 2013 4:44 pm
Yes indeed this is interesting. This really would take away the pain from tinkering and soldering..
However, does the software that manufacturer provides, come with command line commands as well? I guess it would be easy to write some python myself (easy is relative with my almost zero python experience)..
