asandford
Re: [GUIDE] Communicate between iOS and Raspberry Pi using MQTT
Mon Jan 22, 2018 12:24 am
[quote=GhostRaider post_id=1261545 time=1516408691 user_id=174543
How would that work? It's very interesting indeed but how would clients confirm to the mqtt broker that it received the message if brokers aren't allowed to subscribe or publish to anything other than just send messages to their destination? Unless its a modified protocol. I've researched this before, for example someone wanted to create a chat application but wanted to have a feature that the message was received by the other client. The answer was to use a workaround, meaning to use the subscriber/publisher model because you can never confirm that the client handled the message appropriately unless you manually check that message from the client side.
[/quote]
There are other brokers available that have a great deal of added functionality and extend that to the MQTT protocol.
kingofthenorth
Thu Jan 25, 2018 4:56 pm
axopax wrote:
Sat Jan 20, 2018 12:47 am
Hey,
Thanks for the great tutorial. I just had a few issues I wanted to verify.
After i wrote make in the mosquitto terminal, I got so many warnings. Mainly :
../lib/tls_mosq.c:130:5: warning: ‘ASN1_STRING_data’ is deprecated [-Wdeprecated-declarations]
data = ASN1_STRING_data(nval->d.dNSName);
Second, when I added the "mosquitto -v" command, I got :1516409129:
mosquitto version 1.4.14 (build date 2018-01-20 00:39:52+0000) starting
1516409129: Using default config.
1516409129: Opening ipv4 listen socket on port 1883.
1516409129: Error: Address already in use
Could you please help as I am a beginner
Open a terminal and type
ps -ef | grep mosquitto
then execute
sudo kill 123
where 123 is the process ID. Then try executing
mosquitto -v
Francklin
Thu Jan 25, 2018 6:06 pm
Great guide, congratulations!
I will ask something "idiot"...I see the ip to make a communication. So, can I use, for example, 10 iphones into the same server (raspberry pi) ?
Att;
Francklin Souza
kingofthenorth
Thu Jan 25, 2018 6:59 pm
GhostRaider wrote:
Sat Jan 20, 2018 12:14 am
kingofthenorth wrote:
Fri Jan 19, 2018 8:53 pm
So you have to make the Raspberry Pi publish to a topic that the iOS device is subscribed to, and then send the appropriate message like "filedone" or something like that. In iOS, you would have a function that receives messages, decodes it and does a string comparison. So if message == "filedone", then do something.
Thanks for the feedback everyone! It's been very helpful. I'm still not able to receive the message from the Pi. I'm obviously missing something.
Here's a little test app I have in place.
RPi:
import paho.mqtt.client as MQTT
def connectionStatus(client, userdata, flag, rc):
    print("Connecting...")
    mqttClient.subscribe("rpi/hello")
def messageDecoder(client, userdata, msg):
    message = msg.payload.decode(encoding='UTF-8')
    if message == "Hello":
        print("Sending reply...")
        mqttClient.publish("rpi/world", "World")
clientName = "Pi"
serverAddress = ip
mqttClient = MQTT.Client(clientName)
mqttClient.on_connect = connectionStatus
mqttClient.on_message = messageDecoder
mqttClient.connect(serverAddress)
mqttClient.loop_forever()
iOS:
let client = CocoaMQTT(clientID: "iOS Device", host: ip, port: 1883)
@IBAction func connect(_ sender: UIButton) {
  client.connect()
@IBAction func disconnect(_ sender: UIButton) {
  client.disconnect()
@IBAction func send(_ sender: UIButton) {
  client.publish("rpi/hello", withString: "Hello")
  client.subscribe("rpi/world")
func mqtt(_ mqtt: CocoaMQTT, didReceiveMessage message: CocoaMQTTMessage, id: UInt16 ) {
  print(String(bytes: message.payload, encoding: .utf8)!)
MQTT Server:
New Connection from ip on port 1883
New client connection from ip as iOS Device (c1, k60)
Sending CONNACK to iOS Device (0,0)
Received PUBLISH from iOS Device (d0, q1, r0, m8, 'rpi/hello', ...(5 bytes))
Received SUBSCRIBE from iOS Device
rpi/word (QoS 2)
iOS Device 2 rpi/world
Sending SUBACK to iOS Device
I appreciate any help!
kingofthenorth
Thu Jan 25, 2018 7:02 pm
Att;
Francklin Souza
Are you asking if 10 iPhones can publish to the same MQTT server? If so, yes I believe so. As long as 10 iPhone are creating a client to the same IP.
Francklin
Thu Jan 25, 2018 7:13 pm
Att;
Francklin Souza
Exactly!
My situation:
I have a raspberry pi running mosquitto and a program python-based which power on or off a GPIO in accord with a string who receive from iphone. So, I need to make an app for everyone (any iphone) connect on raspberry to control a led, for example.
Is it possible?
kingofthenorth
Thu Jan 25, 2018 7:19 pm
Att;
Francklin Souza
Exactly!
My situation:
Is it possible?
Yes. This is assuming all 10 iPhones are on the same network as the Pi. I've never tried it on different networks. If so, I assume that might be a little more involved.
Francklin
Thu Jan 25, 2018 7:21 pm
Exactly!
My situation:
Is it possible?
At the same network.
Thank you for your help!
GhostRaider
Fri Jan 26, 2018 5:33 am
RPi:
clientName = "Pi"
serverAddress = ip
iOS:
  client.connect()
  client.disconnect()
MQTT Server:
rpi/word (QoS 2)
Does the Raspberry Pi ever receive the message "Hello" from the iOS device? If it doesn't then that could be why.
Guides I have created on the Raspberry Pi Forums:
1) [GUIDE] Raspbian Lite with PIXEL/LXDE/XFCE/MATE/Openbox/i3
2) [GUIDE] Communicate between iOS and Raspberry Pi using MQTT
kingofthenorth
Fri Jan 26, 2018 6:17 am
RPi:
clientName = "Pi"
serverAddress = ip
iOS:
  client.connect()
  client.disconnect()
MQTT Server:
rpi/word (QoS 2)
Yes the Pi is receiving the message "Hello" from the iOS device.
When publish from the iOS device to the Pi, the Pi does a publish on topic /rpi/world. This is how the log looks:
Received PUBLISH from iOS Device ('rpi/hello')
Sending PUBACK to iOS Device
Sending PUBLISH to Pi ('/rpi/hello')
Received PUBLISH from Pi ('/rpi/world')
Sending PUBLISH to iOS Device ('rpi/world')
OldPCGuy
Mon Feb 26, 2018 4:21 pm
Dumb question; how do you take the iOS program you write from simulator to the actual phone?
Never mind figured it out ;)
OldPCGuy
Sun Mar 04, 2018 9:15 pm
When I build the workspace under Xcode v9.2 I get the following error>100 times ;
"Block implicitly retains 'self'; explicitly mention 'self' to indicate this is intended behavior" in the GCDAsyncSocket.m file.
Can these warning be ignored or supressed or do they indicate some other issue?
Figured it out. On the move again! ;)
axopax
Mon Mar 05, 2018 6:30 am
I am trying to link the raspberry pi to the android app MQTT Dashboard. I would like to do so to be able to publish certain messages. What client ID, server, and port should I be using for the MQTT Dashboard app to link them together?
Mon Mar 05, 2018 7:13 am
Where's your broker? Use the IP address for that and port 1883.
mattmiller
Mon Mar 05, 2018 7:14 am
Assuming you've got mosquitto running on your Pi
ClientID can be anything you want (as long as its different to any other ID being used with the Pi)
Server is name or IP address of your pi - I suggest using using IP address if you know it
Port is normally 1883
pwrdwn
Fri Mar 23, 2018 3:46 pm
Does anyone have any other troubleshooting tips besides double checking the IP address? Everything seems to be find, but nothing is happening when I press connect or flip the switch.
OldPCGuy
Sun Apr 01, 2018 2:38 pm
I solved my issue but...
why would the Geany IDE resolve/import the paho.mqtt and the IDLE IDE would not?
should I have installed paho-mqtt under sudo? I get the following error :(
====================== RESTART: /home/pi/MQTTDemo4.py =======================
  File "/home/pi/MQTTDemo4.py", line 4, in <module>
    import paho.mqtt.client as mqtt
ImportError: No module named 'paho'
[email protected]:~ $ pip install paho-mqtt
Collecting paho-mqtt
  Downloading paho-mqtt-1.3.1.tar.gz (80kB)
    100% |████████████████████████████████| 81kB 815kB/s
Building wheels for collected packages: paho-mqtt
  Running setup.py bdist_wheel for paho-mqtt ... done
  Stored in directory: /home/pi/.cache/pip/wheels/20/d8/0d/acdc8f2890111b7be7de71deebef0642fb83be0313dfff0493
Successfully built paho-mqtt
Installing collected packages: paho-mqtt
Successfully installed paho-mqtt-1.3.1
[email protected]:~ $ ^C
asandford
Sun Apr 01, 2018 6:13 pm
Yes
HDST89
Fri Apr 06, 2018 3:44 pm
Thanks for the tutorial, very helpful. Everything worked right away and I added subscribe and unsubscribe. When I subscribe to a published topic from iOS, the broker is receiving the message and forwarding to iOS so I would like to view on the app. What's the MQTT callback in swift to receive message? An example code would be appreciated (as you've done with this tutorial).
MartenKL
Tue May 01, 2018 11:27 pm
Awesome guide, thanks. Too bad pahoo.mqtt isn't available in Pythonista on iOS. That would be a great test environment.
Pheaktra
Wed May 16, 2018 9:33 am
Hi ! So I have follow your post and find out everything work perfectly especially the iOS app but as you only focus on publish message from iOS, can you please help me with how to get iOS subscribed to any topic and display subscribed message on the screen, cuz I'm just the beginner level when talk about swift with mqtt
Thanks you and looking forward to your reply
prwiley
Tue Jun 19, 2018 2:12 pm
I get to the step
git clone https://github.com/eclipse/mosquitto.gi
t
and get
[email protected]:/ $ sudo git clone https://github.com/eclipse/mosquitto.git
Cloning into 'mosquitto'...
remote: Counting objects: 7380, done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 7380 (delta 0), reused 3 (delta 0), pack-reused 7376
Receiving objects: 100% (7380/7380), 2.08 MiB | 0 bytes/s, done.
Resolving deltas: 100% (5632/5632), done.
Checking connectivity... done.
but there is no mosquito directory in my home folder. Would it have gone someplace else?
JMpi82
Mon Jul 16, 2018 3:30 am
When I try to run the program I get the following:
File "/home/pi/mqtt connect to iphone.py", line 4, in <module>
I did import the as follows:
Downloading https://files.pythonhosted.org/packages ... 3.1.tar.gz (80kB)
100% |████████████████████████████████| 81kB 505kB/s
Stored in directory: /home/pi/.cache/pip/wheels/38/ca/67/86c7e4acc659ce5ab74cbb8cc38de50c90ed4f827133e36994
Any advise?
mattmiller
Mon Jul 16, 2018 6:11 am
try it using
sudo pip install paho-mqtt
krishdhar
Wed Jul 25, 2018 10:38 pm
Hi and thank you for the tutorial
Someone already asked this question and I just want some clarification. How would I go about sending messages to the app from the raspberry pi(for example, if an event occurrs, then a switch on the app turns). I just want to know what steps would be required to complete this task.
Thank you
