beejayf
Buffered Sound Detector
Fri Oct 13, 2017 5:31 pm
Hey y'all,
I have a simple sound detector on a GPIO of my RPi. Problem it's that on medium sounds it flips to 1 only very briefly so when I detect the GPIO every few ms there it's a chance the script will miss it. My PIR on the other hand buffer a detection for a few seconds and the script won't miss that.
Any simple way to do this on or for a Pi?
Thanks!
Hoagie
Re: Buffered Sound Detector
Sat Oct 14, 2017 9:05 pm
apparently wiringPi does interrupt based GPIO. check this page out
http://wiringpi.com/reference/priority- ... d-threads/
It looks like you will be able to setup an interrupt to trigger when the pin changes state, even for,an extremely short time.
beejayf
Sun Oct 15, 2017 5:39 pm
Thanks! That was exactly what I was looking for - even better than a soldering solution ;-)
beejayf
Sun Oct 15, 2017 6:40 pm
works like a charm!
SNDdetected is a global variable that I check whenever there is time and the set to zero again
def SNDEventHandler (pin):
    print "Sound detected"
    SNDdetected = 1
GPIO.setmode(GPIO.BOARD)
GPIO.setup(SNDpin, GPIO.IN)
#set interrupt handler
GPIO.add_event_detect(SNDpin, GPIO.BOTH, callback=SNDEventHandler, bouncetime=2000)
