IddoB
Barcode Reader
Fri Sep 08, 2017 1:27 pm
Hi there,
I am looking to read a bar-code (Not sure what specific type yet) using the Raspberry Pi. While looking online I came across 2 options:
The first option would be the best if I can manage to find how to work with the scanners.
Id be happy to hear your input on the subject.
topguy
Re: Barcode Reader
Fri Sep 08, 2017 1:47 pm
For the first link, the clue is in the words "TTL" and "USB".
- TTL means that probably there is a UART/serial interface that works on 5V. Raspberry Pi uses 3.3V on the GPIO serialport so some adaptor chip is recommended.
- USB: Should mean that there is a usb socket (or pins you need to solder a cable to) that you can connect to the USB port on the Pi.
Most likely when you connect the USB it will also be detected as a serialport.
The protocol for barcode scanners are usually very very simple.You scan something and the string is sent over the serialport with a line-feed to signal the end.
But you should probably request detailed interface and protocol description when/before you order any unit.
Re: Barcode Reader
Fri Sep 08, 2017 3:23 pm
Those scanner are so cheap they look like the best bet. They are really easy to interface if using USB, which will just appear as a serial port (as stated above). Just make sure it will read the type of barcode you are planning to use, although I suspect they will do most sorts.
IddoB
Re: Barcode Reader
Fri Sep 08, 2017 3:34 pm
jamesh wrote: Those scanner are so cheap they look like the best bet. They are really easy to interface if using USB, which will just appear as a serial port (as stated above). Just make sure it will read the type of barcode you are planning to use, although I suspect they will do most sorts.
Thank you for this information. Which one of the 2 would you recommend?
Re: Barcode Reader
Fri Sep 08, 2017 4:29 pm
No way of telling from listings and haven't used either.
IddoB
Re: Barcode Reader
Fri Sep 08, 2017 4:48 pm
In the first one it doesnt say that it comes with the connectors, http://prntscr.com/giqqa8
Do you think it does come or I need to buy ones, if so what type of connectors?
