Decoding remote control infrared pulses
Posted: Fri Sep 28, 2012 9:58 pm
by joan
I found a spare IR receiver from some I bought years ago for a LIRC board.
It was surprisingly easy to interface to the Pi and may be useful as a remote control in robotics type applications.
Mine is a http://uk.rs-online.com/web/p/ir-remote ... r/6548930/ but any similarly specified device should work.
Pin 1 to a gpio input, pin 2 to ground, pin 3 to 5V. Originally I fed the gpio input via a voltage divider (resistor pair) but that didn't work so I made a direct connection.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <signal.h>
#include <string.h>
#include <errno.h>
#include <sys/time.h>
#include <wiringPi.h>
#define IR_PULSES 11
#define MS10 10000 /* 10 ms timeout value */
#define STARTBIT 2200
#define BIT1     1000
#define BIT0      400
#define IR_PIN    23
int pulseIn(int pin, int level, int timeout)
   struct timeval tn, t0, t1;
   long micros;
   gettimeofday(&t0, NULL);
   micros = 0;
   while (digitalRead(pin) != level)
      gettimeofday(&tn, NULL);
      if (tn.tv_sec > t0.tv_sec) micros = 1000000L; else micros = 0;
      micros += (tn.tv_usec - t0.tv_usec);
      if (micros > timeout) return 0;
   gettimeofday(&t1, NULL);
   while (digitalRead(pin) == level)
      micros = micros + (tn.tv_usec - t0.tv_usec);
   if (tn.tv_sec > t1.tv_sec) micros = 1000000L; else micros = 0;
   micros = micros + (tn.tv_usec - t1.tv_usec);
   return micros;
int getIRkey()
   int pulse[IR_PULSES];
   int i;
   int result;
   while (pulseIn(IR_PIN, LOW, MS10) < STARTBIT); /* wait for a start bit */
   for (i = 0 ; i < IR_PULSES ; i++) pulse[i] = pulseIn(IR_PIN, LOW, MS10);
   result = 0;
      if      (pulse[i] > BIT1) result |= (1<<i);
      else if (pulse[i] < BIT0) return -1;
   return result;
int main (int argc, char *argv[])
   int key;
   if (wiringPiSetupGpio () == -1)
      fprintf (stderr, "Can't initialise wiringPi: %s\n", strerror (errno)) ;
      return 1 ;
   pinMode(IR_PIN, INPUT);
   while (1)
      key = getIRkey();
      printf("%d\n", key);
I got results from some remote controls but not others. I don't know why, but I'm not familiar with IR protocols. For my needs I only need to find one remote control which works.
Re: Decoding remote control infrared pulses
Posted: Mon Oct 29, 2012 2:27 am
by thisoldgeek
I have the wiringPi Library from git://git.drogon.net/wiringPi installed. When I try to compile your code, I get the following:
gcc -o remote remote.c
/tmp/ccYw5C6J.o: In function `pulseIn':
remote.c:(.text+0x1a0): undefined reference to `digitalRead'
/tmp/ccYw5C6J.o: In function `main':
remote.c:(.text+0x2f4): undefined reference to `wiringPiSetupGpio'
remote.c:(.text+0x384): undefined reference to `pinMode'
collect2: ld returned 1 exit status
I/m a n00b on the Pi and compiling C in Linux, previous experience was a lot of arduino. Something I'm doing wrong? Pulled the wrong wiringPi Library?
-TIA
Posted: Mon Oct 29, 2012 8:23 am
by joan
The linker is reporting it can't find various functions from the wiringPi library. You need to tell gcc to link in the library.
You do that by
gcc -o remote remote.c -lwiringPi
That will compile remote.c, link it with the wiringPi library and produce an executable called remote.
Posted: Mon Oct 29, 2012 5:33 pm
by thisoldgeek
Thanks, the compiler directive worked a treat!
Posted: Sat Nov 10, 2012 7:34 pm
by rotflcopter
Hello, I have one question.
I am getting the same output on every button I press... Is that normal? How can I recognize which button was pressed?
Posted: Sat Nov 10, 2012 7:55 pm
by joan
No, unless you want a one command remote controller.
As I originally said it worked with some remotes but not others. All I can suggest is you muck about with the code and print diagnostics about the pulses actually being received.
Posted: Sun Jan 26, 2020 7:26 pm
by amfasis
Allthough it's been 8 years since this post, I needed a simple code like this using wiringPi (don't like pigpio), but had to fiddle a bit with it. It prints the pulse lengths and the converted key. It's not 100% percent accurate for each button press, but if you get the same number multiple times, you know you got it.
This is my result:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <signal.h>
#include <string.h>
#include <errno.h>
#define IR_PULSES 35
#define TIMEOUT 20000 /* 20 ms timeout value (first pulse should be shorter) */
#define BIT1     1000
#define IR_PIN    22
int pulseIn(int pin, int timeout, long *us_zero, long *us_one)
   long start = micros();
   *us_zero = 0;
   *us_one = 0;
   while (digitalRead(pin) == LOW)
      if(micros() - start > timeout)
         return 0;
   *us_one = micros() - start;
   start = micros();
   while (digitalRead(pin) == HIGH)
         return 0;
   *us_zero = micros() - start;
   return 1;
int getIRkey()
   long high[IR_PULSES];
   long low[IR_PULSES];
   int i;
   int result;
   while(digitalRead(IR_PIN) == HIGH)
   for (i = 0; i < IR_PULSES; i++)
      pulseIn(IR_PIN, TIMEOUT, &low[i], &high[i]);
   for(i = 0;i < IR_PULSES;++i)
      printf("H=%ld, L=%ld\n", high[i], low[i]);
   result = 0;
   for (i = 1; i < IR_PULSES;++i)
      if(low[i] > BIT1)
         result |= (1 << (32 - i));
   return result;
   int key;
      return 1 ;
   while (1)
      key = getIRkey();
      printf("key: %X\n", key);
