Page 2 of 2
Re: Relays and failsafe
Posted: Wed Jun 07, 2017 5:43 pm
by Burngate
It seems to be getting more and more complicated - and the more there is, the more that can fail, leaving it in a non-safe condition.
Assuming you want it to fail safely within a second or so, how about this?
As long as the first fet is hit more than once a second, it'll hold the second one on. If not, the second fet will go off after another second.
Posted: Mon Jun 12, 2017 10:11 am
by PiGraham
Burngate wrote:It seems to be getting more and more complicated - and the more there is, the more that can fail, leaving it in a non-safe condition.
Just off the top of my head, how about just the one FET, series capacitor to the gate and high value resistor from G to S, as you have, and switch the GPIO between output high and input tri-state?
The series C blocks DC if the GPIO sticks high.
Setting the pin to output high injects charge into the gate turning on the FET. The high value resistance discharges the gate in a second or so.
Output low turns FET off.
Stuck high FET turns off.
Keep pulsing out high/ input tri-state to keep the FET on.
Maybe add additional capacitance to the gate.
Posted: Mon Jun 12, 2017 10:46 am
by gordon77
What about something like this vellerman kit.. using as 'Start/Stop Timer' option seems to suit your application.
Just program the pi to do a 'start' pulse (interface required as its 12v) and it will run for a set time, if the pulse stays ON it will still time out according to the instructions.
http://www.velleman.co.uk/manuals/k8015.pdf
