tdenson
IC for driving LEDs
Wed May 24, 2017 8:21 am
I want to drive 6 LEDs from GPIO pins for a project of mine. Obviously I can wire up the LEDs with 6 transistors and resistors, but I thought there would be an IC that does the job for me. However, I have searched all the usual sources (Farnell, RS, eBay etc) in vain. It seems a simple enough requirement.
scotty101
Re: IC for driving LEDs
Wed May 24, 2017 8:31 am
If you just want simple on/off control but need to drive LEDs that require more than the Pi can supply, you could look at something like the ULN2803A, it is a darlington pair array which contains 8 pairs of transistors.Its capable of driving up to 50V and 500mA.
There are obviously similar packages out there with higher ratings.
joan
Wed May 24, 2017 8:49 am
Have a look at the PCA9685. It is an I2C device and provides 16 channels.
It usually comes bundled in a convenient module, generally marketed as a servo driver but it's intended usage is as a PWM LED driver.
E.g. have a look on eBay for PCA9685 and PWM.
tdenson
Wed May 24, 2017 12:20 pm
scotty101 wrote:If you just want simple on/off control but need to drive LEDs that require more than the Pi can supply, you could look at something like the ULN2803A, it is a darlington pair array which contains 8 pairs of transistors.Its capable of driving up to 50V and 500mA.
Perfect, thanks very much
tdenson
Wed May 24, 2017 12:21 pm
joan wrote:Have a look at the PCA9685. It is an I2C device and provides 16 channels.
Thanks, but more sophisticated than I need
pcmanbob
Wed May 24, 2017 8:17 pm
Even if you use a ULN2803A you will still need current limiting resistors in series with your LEDs.
tdenson
Wed May 24, 2017 9:54 pm
Yes, I had assumed that
