trackerj
RaspberryPi - MAINS AC Dimmer Setup
Wed Apr 05, 2017 12:52 pm
RaspberryPi - MAINS AC Dimmer Setup: directly connected MPDMv4 MAINS AC Dimmer board to a Raspberry PI and driving it using the PWM signal provided by the RPi Board thru the onboard gpio extension header:
https://www.youtube.com/watch?v=wqY4-gHqvZI
Related Article with source code: http://www.esp8266-projects.com/2017/04 ... art-1.html
Part 2 will continue with the related Domoticz setup & tests.
ESP8266 MPDMv4 AC MAINS Dimmer Home: http://www.esp8266-projects.com/2016/04/mpdmv4-mains-dimmerswitch.html
Available on Tindie: https://www.tindie.com/products/nEXT_EVO1/
trackerj
Re: RaspberryPi - MAINS AC Dimmer Setup
Fri Apr 14, 2017 8:16 am
Part 2: Domoticz Setup and live testing:
https://www.youtube.com/edit?o=U&video_id=z-eSTDL9qdY
Related source code can be found in the related post here: http://www.esp8266-projects.com/2017/04 ... immer.html
