Oregon Scientific WMR86 Weather Station
Posted: Tue Mar 14, 2017 9:22 pm
by oldfart
Any code around to intercept the 433mhz signals to this weather station?
the sensors are:-
• Wind Sensor (WGR800)
• Temperature and Humidity Sensor (THGR800)
• Rain Gauge (PCR800)
Been round the internet for a couple of weeks - found some code for the Arduino, but not much for the pi.
Found some 433Mhz stuff, but not much help!
TIA
Re: Oregon Scientific WMR86 Weather Station
Posted: Sat Mar 18, 2017 4:41 pm
by Alex Konshin
If you are fluent in C/C++ then you can do it.
See http://www.osengr.org/WxShield/Download ... tocols.pdf
Otherwise you should wait until somebody does it.
I am doing some programming for 433.92MHz receivers and I know that this is not easy. First of all you need a good receiver. So far for this purpose RXB6 is the best that I have tried.
Posted: Sun Mar 19, 2017 9:49 am
by oldfart
thanks - will have a look
Posted: Wed Mar 22, 2017 4:50 pm
by Alex Konshin
If you really want to do it by yourself then I recommend you to look at my project https://github.com/alex-konshin/f007th-rpi
It basically does what you need but for the different sensor (Ambient Weather F007TH). Of course, in your case the protocol is different but you will get an idea how such things should be implemented.
Actually I will update this project soon because I have implemented a driver that should simplify implementation of such utilities. Basically the driver will replace and eliminate the need of pigpio library and will make possible to write a code that will work on other platforms (Banana Pi M3 and MinnowBoard Turbot https://store.netgate.com/Turbot4.aspx in my nearest plans). The driver already works but I am still debugging it.
Posted: Thu Mar 23, 2017 7:28 am
by peterlite
There are a few posts on 433MHz for distances where Wifi does not work, including weather balloons. Google raspberry pi 433MHz.
There are also posts on replacing Oregon Scientific sensors with Pi Zero based sensors, giving you the option to use Wifi. I started looking at that when Oregon Scientific discontinued the outdoors sensor for my kit. The supplied ones were out of the sun but still died way too fast and they would not sell a replacement.
Posted: Sun Apr 23, 2017 9:04 am
by oldfart
Alex Konshin wrote:If you really want to do it by yourself then I recommend you to look at my project https://github.com/alex-konshin/f007th-rpi
Any update on this yet??
Posted: Sun Apr 23, 2017 1:54 pm
by Alex Konshin
Actually there are a lot of updates but I am still working on further improvements and I have not updated instructions.
  • There is a new project where the driver resides: https://github.com/alex-konshin/gpio-ts. The driver has been tested with RPi3 and Banana Pi M3 and it works fine. I am currently working on implementation of support for ODROID C2.
  • The project https://github.com/alex-konshin/f007th-rpi has been already updated and it works with this new driver on RPi3 and BPI-M3. Basically I added a new executable f007th-send that works with gpio-ts driver rather than with pigpio library.
  • I have added support for sensors AcuRite 00592TXR. Actually this is a family of sensors with the same protocol. In particular I use this one: https://www.amazon.com/gp/product/B00T0 ... UTF8&psc=1. This sensor sends data in about every 15 seconds and it has greater range than Ambient Weather F007TH. My receiver also sees 2 other sensors of my neighbors :).
  • I have tested yet another receiver: https://www.amazon.com/gp/product/B012G ... UTF8&psc=1. It works but reception is worse that RXB6. It could be a difference in antenna though.
But I still need to update instructions for both projects. In case of RPi3 it is more or less straight forward but building the driver for BPI-M3 was a nightmare. Especially when you do it for the first time in your life.
Posted: Sun Apr 23, 2017 2:52 pm
by oldfart
Thanks very much for the info .. will play!
[bits now on order]
