itsmedoofer
LM75 Temp Sensor Help
Sun Mar 12, 2017 1:22 pm
I have a LM75 compatible (a MCP9801) temperature sensor connected to my Pi...
My intention is to use this sensor as a "case" temperature monitor for the pi and display the temp in the panel bar
I have successfully setup I2C and can read raw data from the sensor..
i2cget -y 1 0x4f 0x00 w |awk '{printf("%0.1f C\n",(a=((("0x"substr($1,5,2)substr($1,3,1))*0.0625)+0.1) )>128?a-256:a)}'
I've had a play with lm-sensors but the sensor is not seen when I run the detect script....
What I think I need to do is make it available as a device... I see the the kernel has a LM75 driver, but how do I get the driver to see the sensor ?
Do I need an overlay to tell the driver where the sensor is on the I2C bus if so how can I go about it...
Thanks in advance...
itsmedoofer
Re: LM75 Temp Sensor Help
Tue Mar 14, 2017 10:14 am
I've done a bit of work and got a working LM75 setup with a driver that can be used to display the sensor temp on the panel bar at the top of Pixel....
This is a I2C sensor so you will need to enable I2C in raspi-config if not already done so, you will also need i2c-tools to test..
sudo apt-get i2c-tools
There are plenty of guides detailing I2C setup so I wont go into this any further....
With I2C setup you can verify that the sensor is connected and working by reading the raw data from it using the following....
LM75 compatible devices already have a kernel driver in Rasbain, so to make the sensor a device all we have to do is enable it using an overlay...
Until the overlay is made available in the distribution you can download it from here:-
viewtopic.php?p=1129909#p1129909
This needs to be copied into /boot/overlays backing up the original one first..
The instructions in that post are slightly wrong the following needs to be added to /boot/config.txt
dtoverlay=i2c-sensor,lm75
After a reboot you can check things are loaded correctly by:-
dmesg|grep lm75
You should see something like this if everything is working correctly...
[ 6.738872] lm75 1-004f: hwmon0: sensor 'lm75'
I wanted to use the sensor as a case monitor for my Pi and have the temperature displayed on the panel bar at the top of Pixel.....
Firstly the lm-sensors package is required
sudo apt-get install lm-sensors
And then configure it for use:-
sudo sensors-detect
Say YES (enter) to all the questions, until....
Do you want to add these lines automatically to /etc/modules? (yes/NO) , you will need to type Y here unless you want to make the modifications yourself..
Reboot and check everything is setup correctly by typing sensors, if everything is working correctly you should see
sensors
lm75-i2c-1-4f
Adapter: 3f804000.i2c
temp1: +18.5°C (high = +80.0°C, hyst = +75.0°C)
To display the sensors temperature in the top panel of Rasbian you will need to compile a small applet for LXPanel..
Download and unpack the source code from here:-
http://danamlund.dk/sensors_lxpanel_plugin/
The packages required to compile on the raspberry are slightly different from what is shown in the instructions on the page..
sudo apt-get install libglib2.0-dev libgtk2.0-dev libmenu-cache-dev libsensors4-dev
Once these are installed change directory to where you extracted the source and type..
make
sudo make install
Compilation will take seconds...
After a reboot there will be an additional applet available in Panel Settings -> Panel Aplets -> Add -> “lm-sensors Monitor” This will display the sensor temp in the panel bar at the top of Pixel.....
For a clean up you can remove the source directory and the development packages...
sudo apt-get remove libglib2.0-dev libgtk2.0-dev libmenu-cache-dev libsensors4-dev
sudo apt-get autoremove
I appreciate this is not a complete guide but intermediate users should find it useful...
gregeric
Tue Mar 14, 2017 11:17 am
Thanks for that!
The PaPiRus HATs include an LM75, so this is useful to owners of those boards.
