tdenson
Is it possible to supply power via IO pins
Sun Jan 29, 2017 10:44 am
Are the power pins on the IO pins just outputs, or is it possible to power the Pi via them instead of the micro USB socket.
Re: Is it possible to supply power via IO pins
Sun Jan 29, 2017 11:18 am
You can supply 5V power using either of the 5V pins and a Ground pin, but this will bypass the on-board fuse (on all models except the Zero which doesn't have one).
tdenson
Sun Jan 29, 2017 11:22 am
Probably not a good idea then. I was looking at mounting a Pi on a PCB and wanted to minimise the amount of physical wiring.
Sun Jan 29, 2017 11:35 am
You could always add your own fuse between the 5V pin and your power input.
mattmiller
Sun Jan 29, 2017 11:57 am
As long as cn ensure that your power supply isn't going to give out more than 5.2V, then you'll be fine
tdenson
Sun Jan 29, 2017 12:10 pm
No, I think I'll come up with a custom micro USB lead with a plug that connects to a socket on my PCB.
tdenson
Sun Jan 29, 2017 12:12 pm
Also, I've just spotted a massive flaw in my plan A - there's no easy way to power cycle
