pigpio and pilight-raw
Posted: Tue Dec 20, 2016 10:06 pm
by andies
Is there a program similar to
pilight-raw -L
in the pigpio-library? I am struggling with my garage door opener and need the raw codes. I only partially understand the pilight-library, the code might be well documented but the wiki is not and many things are not well described (what is the difference between pulse, pulse train, pulse length, raw length etc. pp.). The pilight-forum also seems to be a little sleepy. Nevertheless, what I like is the above raw-command but there does not seem to be a similar program in pigpio? There, I could only find piscope but recording the piscope is such a pain because of the only graphical interface (it is not build for recording but watching).
Re: pigpio and pilight-raw
Posted: Tue Dec 20, 2016 10:22 pm
by joan
What does pilight-raw do?
Posted: Wed Dec 21, 2016 8:16 pm
by andies
It seems to send raw data ("noise") to output. The difference to Piscope is that Piscope gives me a picture or a movie, pilight-raw gives me the actual numbers. From the wiki (although the description is a little bit terse):
pilight-raw will output raw numbers representing the time difference in µs (microseconds) between a low-to-high or a high-to-low transition forming a pulse. Depending on the protocol code a set of multiple pulses, typically two or four pulses, are representing a logical ZERO or ONE condition. A pulsetrain is a series of logical bits normally terminated by a footer pulse (last long distinct pulse).
pilight-raw can print raw data in two different formats:
pilight-raw -L or pilight-raw –linefeed:
433gpio: 1180 590 590 1180 1180 590 1180 590 1180 590 590 1180 590 1180 1180 590 1180 590
590 1180 1180 590 590 1180 590 1180 590 1180 590 1180 590 1180 1180 590 1180 590
1180 590 1180 590 590 1180 590 1180 590 1180 590 1180 590 1180 590 1180 1180 590
590 1180 590 1180 1180 590 590 1180 1180 590 590 6785 -#: 66
Posted: Wed Dec 21, 2016 8:22 pm
by joan
Okay the following script will capture the raw information. It would have to be post processed to make it pretty.
#!/usr/bin/env python
# monitor.py
# 2016-09-17
# Public Domain
# monitor.py          # monitor all GPIO
# monitor.py 23 24 25 # monitor GPIO 23, 24, and 25
import sys
import time
import pigpio
last = [None]*32
cb = []
def cbf(GPIO, level, tick):
   if last[GPIO] is not None:
      diff = pigpio.tickDiff(last[GPIO], tick)
      print("G={} l={} d={}".format(GPIO, level, diff))
   last[GPIO] = tick
pi = pigpio.pi()
if not pi.connected:
   exit()
if len(sys.argv) == 1:
   G = range(0, 32)
else:
   G = []
   for a in sys.argv[1:]:
      G.append(int(a))
for g in G:
   cb.append(pi.callback(g, pigpio.EITHER_EDGE, cbf))
try:
   while True:
      time.sleep(60)
except KeyboardInterrupt:
   print("\nTidying up")
   for c in cb:
      c.cancel()
pi.stop()
Posted: Fri Dec 23, 2016 10:22 am
by andies
Thank you, great code. May I ask you again: I would like to stop the recording after a defined amount of time. I do see that the particular step to be changed is
while True:
but unfortunately I do not understand the rest of the code (for example: where is tick defined? Could I add a counter without corrupting the speed and hence the time accuracy of the program etc.). Could you help me with that matter?
What I want is the following. I want to record signals after I press a button at my Garage door opener. I do know that the opener sends a wake-up signal as long as I press the button down (around 400us "high" and around 400us "low"). If I release the button the signal unknown to me is transmitted. But if I stop the program manually I add around 50k or more of "noise" and that makes it very hard for me to analyse anything. Stopping the program automatically after 0.5sec would be helpful.
Posted: Fri Jan 06, 2017 7:45 pm
by andies
I have used the code for a while and compared it to pilight-raw. Unfortunately, python (or the RPi) seems to be too slow. The values differ a lot, as far as I can see from actual values that I recorded, in particular using histograms, pilight-raw gives more reliable results. If I am transmitting a 50microsec-LOW-50microsec-HIGH stream to any sender and record the result using this code the histogram is very distorted (contains values of 300 and above) whereas with pilight-raw all values are between 40 and 60.
Posted: Fri Jan 06, 2017 8:18 pm
by joan
andies wrote:I have used the code for a while and compared it to pilight-raw. Unfortunately, python (or the RPi) seems to be too slow. The values differ a lot, as far as I can see from actual values that I recorded, in particular using histograms, pilight-raw gives more reliable results. If I am transmitting a 50microsec-LOW-50microsec-HIGH stream to any sender and record the result using this code the histogram is very distorted (contains values of 300 and above) whereas with pilight-raw all values are between 40 and 60.
If that is with pigpio you are not using it properly. pigpio has no problems capturing a 50 µs level change on a GPIO.
Posted: Fri Jan 06, 2017 8:40 pm
by andies
joan wrote:If that is with pigpio you are not using it properly.
You are right (and it has nothing to do with python): I made a mistake in my breadboard. Now I am capturing 50-50-signals correctly with both software codes.
