roboneo
Automated Warehouse indicators
Tue Oct 04, 2016 5:12 pm
Hi! Im making a proyect to help a worker in his Warehouse, the idea is to make a kind of parking lot light system, where a green Led turn on when theres is material on the location and red when the location has material.
I searched a bit and found That this could be done with pubnub and the HC-SR04, here's the link https://www.google.com.mx/amp/s/www.pub ... camovil-mx
But my problem is That the Warehouse has 15 locations, so, could it be possible to use more tan 1 sensor for every raspberry so i wouldnt need 15?
Thank you so much!
BMS Doug
Re: Automated Warehouse indicators
Wed Oct 05, 2016 9:31 pm
Yes, you'll be able to connect them all to one pi if you want, although you would need an i/o expander and might have problems with the physical distance between the bays.
I'd suggest using a bunch of arduinos instead of the pi.
One arduino nano v3 could do 4 locations.
Doug.
