yonubear
rf decoding help needed
Sun Sep 25, 2016 2:06 am
would anyone be willing to help me with some rf decoding I have the audio recorded to a audacity project just to be honest not sure where to start decoding it as the sensor ID is letters and numbers.
oh I almost forgot they are 433mhz sensors
Thanks,
Yonu
aBUGSworstnightmare
Re: rf decoding help needed
Sun Sep 25, 2016 7:06 am
Don't know if this will help you but you may want to try TI's packet sniffer software http://www.ti.com/tool/packet-sniffer
yonubear
Thu Sep 29, 2016 2:40 am
ok I wanted to say thanks for the links but now I am totally lost. If anyone can help me out with the decoding it would be great. also if it helps the sensers are from a simplisafe alarmsystem.
Thanks,
yonu
joan
Thu Sep 29, 2016 7:48 am
The only help we can give is solely based on the information you provide.
Massi
Thu Sep 29, 2016 8:29 am
yonubear wrote:ok I wanted to say thanks for the links but now I am totally lost. If anyone can help me out with the decoding it would be great. also if it helps the sensers are from a simplisafe alarmsystem.
Thanks,
yonu
before being able to decode a signal, you need to know how the signal is made.
for example, is it an OOK signal?
did you manage to record it and graph it?
THEN you can try to write some code to decode it.
It also depends on the hardware you are using to receive the signal.
I tried with a chinese cheap receiver (something like 1€ on ebay) and could get an amazing range of.. 5cm :lol:
so, look deeper at the signal, than come back :)
