Andries.Schrenk
Raspberry Pi Communication Using CODESYS
Thu Sep 08, 2016 8:27 pm
Hi.
How do I set up communication between 2 or more Raspberry Pi`s on Ethernet protocol using CODESYS software.
Any help will be highly appreciated.
ranpitime
Re: Raspberry Pi Communication Using CODESYS
Wed Sep 21, 2016 4:20 am
Hi Andreas,
You have several options.
1.Network variables here is an example Project for this: http://store.codesys.com/mixedsearch/mi ... duct_area=
2. Modbus example will follow
3 Ethernet IP Scanner the other is Ethernet IP Adapter here is an example Project for this
http://forum.codesys.com/viewtopic.php? ... 503#p14144
beside the Elsner Wetterstation there is a communication between Raspberry PI and another CODESYS plc in this application
BR
ranpitime
