adafruit
DHT Humidity Sensing - Raspberry Pi with Google Docs logging
Mon Aug 27, 2012 10:27 am
Time to start exploring more sensors with the Raspberry Pi! Here's a fun tutorial using DHT11, DHT22 and AM2302 humidity and temperature sensors.
In this tutorial we’ll be showing how to utilize C for high-speed GPIO polling to handle bit-banged sensor output. Many low cost sensors have unusual output formats, and in this case, a “Manchester-esque” output that is not SPI, I2C or 1-Wire compatible must be polled continuously by the Pi to decode. Luckily, the C GPIO libraries are fast enough to decode the output.
http://youtu.be/Skr2uPZzviM
http://learn.adafruit.com/dht-humidity- ... cs-logging
NewPi
Re: DHT Humidity Sensing - Raspberry Pi with Google Docs log
Wed Aug 29, 2012 1:00 pm
Awesome, thanks for posting this. I was looking for something like this to get started with my first electronics hobby project - a basic temperature and humidity sensor using Rpi.
Can we use this instead of DHT11/22 - http://www.adafruit.com/products/381, if yes do we need to change anything ?
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
adafruit
Wed Aug 29, 2012 2:38 pm
see:
http://learn.adafruit.com/dht-humidity- ... the-c-code
"First up, we'll test the C code to verify it works. Wire up a DHT sensor connected up so the data line is on GPIO #4, and powered to 3.3V and ground. If you are using a DHT11 or DHT22 you should add a 4.7K - 10KΩ resistor between the Data pin and the VCC pin.
Then run
sudo ./Adafruit_DHT type pin#"
cheers!
NewPi
Thu Aug 30, 2012 2:03 am
adafruit wrote:see:
Then run
cheers!
Thanks, but my question was will adafruit "Waterproof DS18B20 Digital temperature sensor" work the same way or will there be any changes needed, or could there be any compatibility issues ?
adafruit
Thu Aug 30, 2012 2:14 am
NewPi wrote: Thanks, but my question was will adafruit "Waterproof DS18B20 Digital temperature sensor" work the same way or will there be any changes needed, or could there be any compatibility issues ?
sorry, it was unclear that "this" meant :) you wrote:
NewPi wrote:Can we use this instead of DHT11/22 - http://www.adafruit.com/products/381, if yes do we need to change anything ?
if this="Waterproof DS18B20 Digital temperature sensor", then no - completely different sensor.
cheers!
NewPi
Thu Aug 30, 2012 2:30 am
cheers!
Oops should have linked http://www.adafruit.com/products/381 right after the word "this". Having a waterproof temperature and humidity sensor communicate with rpi would have definitely been more tempting for external environment data logging (imagine cheap weather data collecting rpi's scattered all across the globe uploading real-time environment data to internet).
Would hope you would post something related in near future ;)
adafruit
Thu Aug 30, 2012 2:32 am
stay tuned, we have a few hundred tutorials on the way... :)
RaspberryGeek
Tue Sep 04, 2012 10:24 pm
hi adafruit,
I'm stuggling to get the code working :)
sourced my adafruit parts from the UK (skpang) code appeared to install fine.
I can get my pi to talk happily to a BMP085 and have used the skpang traffic lights program, so i know that generally it can communicate fine.. here's what i get:
pi@raspberrypi ~/dev/adafruit/DHT_Driver $ sudo ./Adafruit_DHT 22 4
Using pin #4
Data (0): 0x0 0x0 0x0 0x0 0x0
What steps should I take to debug ensure that the drivers are working?
Gordon
adafruit
Tue Sep 04, 2012 10:31 pm
hmm, try another a pin just in case - make sure you have a pull resistor... a scope' is the best tool to help troubleshoot too!
monirul.pathan
Wed Sep 05, 2012 9:57 pm
I'm getting the same result as RaspberryGeek with an RHT-03 which is essentially the same as the DHT-22. Have tried other pins as well but no luck.
pi@raspberrypi ~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_DHT_Driver $ sudo ./Adafruit_DHT 22 4
Using pin #4
danpeirce
Thu Sep 06, 2012 6:26 am
adafruit wrote:stay tuned, we have a few hundred tutorials on the way... :)
I am curious about the Google doc's side of the project using the python package. Can you point out where we can find more documentation on that? Any security issues?
RaspberryGeek
Thu Sep 06, 2012 3:35 pm
Yep have got a pull up resistor installed, no access to a a scope (got a FLUKE multi-tester :) )
Have tried different pins, same answer - could it be the DHT22 ?
Scope arriving tomorrow - ho to use it?
RaspberryGeek
Sat Sep 08, 2012 10:59 pm
OK, got a scope - DSO Nano V2 , uprgraded to BenF 3.64
And the scope works just fine.
I can connect the probe leads to the data and grnd,
What settings should I use on the scope (TD, TriggerAuto / Scan, etc) and what am I looking for?
Also got a couple more DHT22's which turned out to be RHT03's - allegedly the same but see here:
https://www.sparkfun.com/products/10167
should we connect pin 3 to 4 to ground?
RaspberryGeek
Sun Sep 09, 2012 8:13 am
OK, so the data pin goes low and then high when running the code sudo ./Adafruit_DHT
here are the Oscilloscpe traces:
https://picasaweb.google.com/1132605127 ... directlink
RaspberryGeek
Fri Sep 14, 2012 1:51 am
OK so there's a bug in the C codeing :)
I wrote a litlle python routine to set the pin high and low, and if i run that in between trying to run the C routing, it gives me the reading everytime!
So £80 spent on an oscilloscope .... - Lesson learnt!
I'll spend some time over the weekend finding out just what the bug is!
lcd15000
Sun Sep 16, 2012 11:08 pm
Any chance on getting a dht python library?
RaspberryGeek
Tue Sep 18, 2012 6:10 pm
Problem is apparently the speed of access via python hence the C application,
According to Adafruit:
Since the DHT sensors use a low-level "Manchester-esque" timing protocol to send data, we need to be able to read the pin they are connected to at very high speeds. The python libraries aren't fast enough, but the low level C libraries are! The code we wrote is a good example of how to deal with bitbang in user space, without the need to write a kernel driver
Except the code doesn't work 'out of the box' ...
discovery
Tue Sep 18, 2012 7:23 pm
I'm also getting the same result as RaspberryGeek and monirul.pathan with an DHT22. This is not working. :evil:
lcd15000
Wed Sep 19, 2012 5:23 am
I am seeing that the driver does not work as well
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l GNU/Linux
root@raspberrypi:/home/pi/adafruit-Adafruit-Raspberry-Pi-Python-Code-1495781/Adafruit_DHT_Driver# while true; do ./ Adafruit_DHT 2302 4;sleep 10;done
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
^C
lcd15000
Wed Sep 19, 2012 6:49 am
I tried the Occidentalisv02 image and got the same responses as well
Linux raspberrypi 3.1.9adafruit+ #10 PREEMPT Thu Aug 30 20:07:05 EDT 2012 armv6l GNU/Linux
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
lcd15000
Wed Sep 19, 2012 7:29 am
after messing around with it for a little while and adding a 10k resistor, I can sometimes get it to respond, but I can not figure out why, it will only work once then not:
$ sudo ./test.py
Using pin #4
Data (40): 0x1 0x86 0x1 0x16 0x9e
Temp = 27.8 *C, Hum = 39.0 %
Temperature: 27.8 C
Humidity: 39.0 %
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
Using pin #4
^CTraceback (most recent call last):
File "./test.py", line 16, in <module>
time.sleep(3)
KeyboardInterrupt
alex25
Thu Sep 20, 2012 6:32 pm
Same as for lcd15000
Most of the time only 0x0 data from the sensor. Only very rarely the correct values.
@RaspberryGeek. Can you share your solution?
lcd15000
Sat Sep 22, 2012 2:38 pm
@alex25 and @RaspberryGeek I took a look at the C code from the DHT library and found this, not sure what the purpose is to set the pin high sleep then set it low. I am not a programer by any means, but when I get a few min I may try to hack this up a bit to see what happens. After all that is what this platform is supposed to inspire right?
 77   // Set GPIO pin to output
 78   bcm2835_gpio_fsel(pin, BCM2835_GPIO_FSEL_OUTP);
 79   bcm2835_gpio_write(pin, HIGH);
 80   usleep(100);
 81   bcm2835_gpio_write(pin, LOW);
 82   usleep(20000);
 83   bcm2835_gpio_fsel(pin, BCM2835_GPIO_FSEL_INPT);
 84
 85   data[0] = data[1] = data[2] = data[3] = data[4] = 0;
alex25
Sat Sep 22, 2012 3:54 pm
lcd15000 wrote:@alex25 and @RaspberryGeek I took a look at the C code from the DHT library and found this, not sure what the purpose is to set the pin high sleep then set it low. I am not a programer by any means, but when I get a few min I may try to hack this up a bit to see what happens. After all that is what this platform is supposed to inspire right?
 80   usleep(100);
 82   usleep(20000);
 84
Indeed. If I set the waiting time between the HIGH and LOW phase to 500ms (500'000us) the sensor replies with the correct values most of the time. However, from time to time I still get faulty values. But great progress so far. Thanks
