photomankc
Anyone sucessful in getting I2C /dev entries to show up?
Fri Aug 24, 2012 2:16 pm
I'm currently working on the idea to give my mobile robot a brain upgrade with the Raspberry Pi and now have my hands on 3 boards to start working with. I foolishly assumed that with the I2C broken out on the GPIO header that there would be already integrated drivers for this. Thus far I have had zero success in getting even as far as having /dev/i2c-0 show up to start from. My robot was designed all around I2C with microcontrollers so getting this working is pretty central to the concept.
I have followed the instructions out here to get a kernel that was supposed to have the drivers compiled into it and update the firmware as well:
http://www.bootc.net/archives/2012/05/1 ... pberry-pi/
After installing his kernel package and copying it over to kernel.img I see no indication in dmesg that anything related to I2C occurs? I'm pretty far from a linux guru and so this whole process seems rather painful to get to the point that you can use the stuff broken out on the GPIO. That's not a dig, just an observation coming to this as someone that does not eat and breathe linux.
fbutler
Re: Anyone sucessful in getting I2C /dev entries to show up?
Fri Aug 24, 2012 6:15 pm
Have a look at the /etc/modprobe.d/raspi-blacklist.conf file, comment out the two lines:
blacklist spi-bcm2708
blacklist i2c-bcm2708
and reboot. The devices :
spidev0.0
spidev0.1
should then appear in the /dev/ directory
PeterO
Fri Aug 24, 2012 9:05 pm
It seems the information about needing a custom kernel is out of date.
My PI is running 3.2.27+ #60 , and after removing the entry in /etc/modprobe.d/raspi-blacklist.conf
and running "sudo modprobe i2c-dev" the devices appeared and are working.
I used the code at http://www.robot-electronics.co.uk/files/rpi_cmps03.c and modified it for the MCP23017's address, and I can read back one of the port registers. I just need to sort out the ownership of the files in /dev.
It was much simpler than I expected !
PeterO
joan
Fri Aug 24, 2012 9:34 pm
After the modprobe I do
sudo chmod o+rw /dev/i2c*
to allow access to the i2c devices as a standard user.
photomankc
Fri Aug 24, 2012 10:22 pm
Awesome. That would have been cool info to know! Anyway, removing the blacklist fixed it right up and I see the /dev/i2c-0 and /dev/i2c-1 entries in there now. Thanks for the info!
catmaker
Fri Aug 24, 2012 10:54 pm
joan wrote:After the modprobe I do
I also noticed that after you install i2c-tools with apt-get
sudo apt-get update
sudo apt-get install i2c-tools
the group i2c is made. After which you can upgrade a user's premissions [edit:incomplete sentence] to gain access to the i2c devices.
sudo usermod -aG i2c yourusername
PeterO
Fri Aug 24, 2012 11:19 pm
catmaker wrote:[
sudo apt-get update
Thanks for that "Top Tip" :-)
PeterO
catmaker
Mon Sep 03, 2012 1:45 am
catmaker wrote:Thanks for that "Top Tip" :-)
PeterO
Ha ha, you're welcome. Really, it was an accidental discovery :)
garym1957
Tue Sep 18, 2012 3:05 am
This is great. Thanks very much for the good advice.
How do I automatically modprobe AND change permissions to the /dev/i2c-0 file at boot time?
Can I run a shell script at boot time?
catmaker
Tue Sep 18, 2012 4:21 am
garym1957 wrote:This is great. Thanks very much for the good advice.
In my experiments, I found that there isn't a need to remove the blacklisting from /etc/modprobe.d/raspi-blacklist.conf -- I just added two lines to the /etc/modules and they look like below (it must be some override thingy, but YMMV) :
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
snd-bcm2835
i2c-dev
i2c-bcm2708
This makes the kernel automatically load up the necessary I2C modules and gives you the /dev/i2c-* devices.
I don't know how to adjust the permissions of the devices at boot time yet, so I just made myself a groupie to the I2C group with the usermod command described in the above message. (There are many sub-directories under /etc/rc*.d or /etc/init which will run a script at boot time, but I prefer not to touch them).
tedhale
Thu Sep 20, 2012 4:56 pm
The simplest way to add commands that will be executed at startup is to edit the file
/etc/rc.local
This script is intended for misc. stuff needed at startup, so it's pretty safe to mess with.
It will run at the end of the startup process.
-Ted Hale
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
catmaker
Fri Sep 21, 2012 2:28 am
tedhale wrote: /etc/rc.local
Nice one, Ted. Thanks!
konsumer
Sun Sep 23, 2012 9:00 am
this helps with permissions.
konsumer
Sun Sep 23, 2012 11:15 am
More specifically, put this in a file called /etc/udev/udev.rules:
# i2c devices
KERNEL=="i2c-[0-9]*",	NAME="i2c/%n", SYMLINK+="%k"
There are other useful lines in there, though.
