SN
Re: Door Bell Server
Mon Feb 11, 2013 11:15 pm
see my Ninja Pi post http://www.raspberrypi.org/phpBB3/viewt ... 37&t=32021
I think this will provide all the glue you need to make things happen when you've sorted the GPIO bit
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
lianamira
Thu Jul 18, 2013 5:38 pm
hi cjpanici... how about the progress of the door bell with camera..? i'am very interesting... i want to try make it too... please reply..
cjpanici
Wed Oct 16, 2013 9:44 pm
Quick update on my doorbell server: I have successfully built a RPi circuit that monitors the existing door bell coil. The picture is attached. I ended up putting the doorbell coil in parallel with the control relay coil and used a 13VAC Dayton control relay; this was because I measured 13VAC across the door bell coil when the door bell switch was met.
If anyone has any questions please let me know.
Also, I am modifying the server python code to run in "headless" mode, and modifying the client apps to detect when the server is disconnected from the network due to a power being cut / shutdown without shutting down the server script.
Thanks,
neech
