How to move Mount Fuji (and the rest)
Posted: Tue May 17, 2016 3:50 pm
Folks,
I want to take an illuminated globe and rig it with a pi so that its position (relative to the tilt) matches the real Earth.
This is entirely pointless, but I think it would be cool.
The globe will also have a clock and will glow when the kids are allowed to get up.
Which is not pointless, but is less cool.
My question is, how should I power the motion of the globe in such a way that I know where it is, given the fundamental requirement that the kids will turn it manually no matter how much I tell them not to?
My thinking is that if the globe is manually turned its motion should pick up again when it is in the right position.
My thoughts so far are:
I write software, I know very little about electronics.
Jim
- Power it with a stepper motor, but how will that react to being forced?
- Power it with a standard geared DC motor and have some kind of sensor that tells me where it currently is.
- I can't fix a magnetometer to the globe because the cables would twist, but could I fix a magnetometer to the core and a magnet to the globe?
- If the power is a standard geared DC motor the drive should be a rubber wheel against a ring (slipper clutch) - but I can't do that if the motor is the position sensor.
Jim
