Hateful7
6 Sensors, 800sps each via I2C
Wed May 11, 2016 1:13 pm
Hello everybody!
My task is to take around 800 samples per second (800 would be nice, but if that is not possible: as many samples as possible) from 6 sensors for an experiment that lasts around 3 minutes.
I have access to a Pi2 and a Pi3 and am planning to use ADS1115 and read from those via I2C.
I already found the WiringPi Library and am able to read data from a ADS1115.
At the moment i don't know how to continue. So i am asking you guys if you can give me information on the following topics or if you can point me to articles or subjects that cover these things so i can find out how this can be done:
1) Will i be capable of sampling with 6 ADS1115 at around 800sps each?
2) Will the sampling rates be somewhat constant?
2.5) Maybe use an os-extension/modification that enables real time tasks?
3) What can i do to control the sampling rate? What is the bottleneck?
4) Would you recommend using the WiringPi Library in this case or is it linked to a lot of overhead?
5) I am planning to use C for reading from the I2C-bus but will it be much faster than the same thing done in Python?
That's all that comes to my mind right now.
Thanks and best regards
Hateful7
Hateful7
Re: 6 Sensors, 800sps each via I2C
Sun May 22, 2016 7:04 pm
Nobody in the mood to help?
danjperron
Sun May 22, 2016 8:07 pm
I did 5000 samples / sec using a small cpu
viewtopic.php?p=530500#p530500
But because I had a cpu I was able to buffer the data. This way I didn't have any problem with the user space.
Did you try you A/D converter? What is your sample rate and your problem with the user space when the kernel access something else.
Daniel
