s.chinmay02
Facing some problem in a small home automation project
Sat Apr 30, 2016 5:45 am
Hello everyone,
I am a newbie in IoT and applications of Raspberry Pi.
I am working on a small home automation project which consists of following sensors:
1. Pressure
2. Proximity
3. Temperature
4. Current
5. Vibration
I have codes for all the sensors and I can read sensor data when they are connected to RPi GPIO.
But, I want to place these sensors in different rooms (as it's a small part of home automation).
I don't understand how to read sensor data on Rpi when they are at different locations.
I have some questions:
1. Can you suggest me which wifi module should I use for sensors and which for RPi?
2. Can wifi module transfer sensor data to raspberry pi?
3. I have all the sensors, RPi and other required equipment except Wifi Module.
I am able to get sensor data when sensors are directly connected to RPi.
As per your suggestion, which wifi module should I purchase?
Will it be compatible with all the sensors?
4. Do I need Arduino Uno?
After surfing the internet I came to know about ESP8266 wifi module,
* Can ESP8266 transfer sensor data to raspberry pi?
* Does it require to have a mediator like Uno dev board to transfer data?
alfista2600
Re: Facing some problem in a small home automation project
Thu May 12, 2016 9:26 pm
I'm not a pro, but I'd suggest using the ESP8266 and a MQTT broker/publisher.
Found a link here which seems like a good guide, but use this to start your research.
http://www.instructables.com/id/An-inex ... g-ESP8266/
RaspberryPi2
Thu May 12, 2016 9:45 pm
Its not very efficient and it may be more expensive, but you could buy multipule RPi zeros.
drekthrall
Wed May 18, 2016 8:40 am
The best solution is esp8266
The best module I tried is this: http://www.wemos.cc/Products/d1_mini.html . It is cheap and can be programmed with arduino IDE with esp8266 library. I am very satisfied with this product :)
fruit-uk
Wed May 18, 2016 8:56 am
I'm quite happy with panStamps http://panstamp.com/ for remote sensors :)
B06jxd
Thu May 26, 2016 6:15 pm
Just following up on this, I am trying to accomlish something similar I.e. Monitor temps, control lights in multiple rooms etc. however I don't understand what I need from a wifi communication standpoint to point back to one raspberry pi which would control each device around the house. Again looking for input.
