coskukoz
8 Analog - 8 Digital Input Raspberry Pi Prototype
Fri Apr 29, 2016 6:32 am
Hi People,
I made a project and want to share it with you all. I hope it help you.
In this project Raspberry Pi has totally 16 Input which are 8 analog and 8 digital. Each input show and transmit one data in the 15 mins. As a database I use Google Spreadsheets. These data shown on the website as daily, weekly, monthly, annual and last data.
I programmed Raspberry Pi on Phyton. The website is HTML, CSS and Javascript.
Digital Input: 0-24V
Analog Input: 0-10V
You can see the overview of this project on the picture below.
Overview of the project
The Materials;
  • Raspberry Pi 2 B
  • MCP3008 ADC
  • 8X1k
  • 8x470ohm
  • 8x820ohm
  • 8x4.7k
  • 8x121ohm
  • 8xLED
The circuit of the digital inputs:
The circuit of the analog inputs:
Note :
I attached other pictures on the next post because of the picture limit.
# 8 Analog - 8 Digital Input Raspberry Pi Python Code #
# Berufsakademie Bautzen #
# Coskun Kozakbas #
import spidev
import time
import os
import urllib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
spi = spidev.SpiDev()
spi.open(0,0)
def ReadChannel(channel):
 adc = spi.xfer2([1,(8+channel)<<4,0])
 data = ((adc[1]&3) << 8) + adc[2]
 return data
def ConvertVolts(data,places):
 volts = (data * 10) / float(1023)
 volts = round(volts,places)
 return volts
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
GPIO.setwarnings(False)
GPIO.setup(5, GPIO.IN)
GPIO.setup(6, GPIO.IN)
GPIO.setup(13, GPIO.IN)
GPIO.setup(19, GPIO.IN)
GPIO.setup(26, GPIO.IN)
GPIO.setup(16, GPIO.IN)
GPIO.setup(20, GPIO.IN)
GPIO.setup(21, GPIO.IN)
while True:
 foldtime = time.time()
 fnewtime = time.time()
 fstore = 900.0                                 # saniye
 while True:
   fdtime = fnewtime-foldtime
   digital1 = GPIO.input(5)
   digital2 = GPIO.input(6)
   digital3 = GPIO.input(13)
   digital4 = GPIO.input(19)
   digital5 = GPIO.input(26)
   digital6 = GPIO.input(21)
   digital7 = GPIO.input(20)
   digital8 = GPIO.input(16)
   if digital1 == 1:
    digital1 = 'ON'
   else:
     digital1 = 'OFF'
   if digital2 == 1:
    digital2 = 'ON'
   else:
     digital2 = 'OFF'
   if digital3 == 1:
    digital3 = 'ON'
   else:
     digital3 = 'OFF'
   if digital4 == 1:
    digital4 = 'ON'
   else:
     digital4 = 'OFF'
   if digital5 == 1:
    digital5 = 'ON'
   else:
     digital5 = 'OFF'
   if digital6 == 1:
    digital6 = 'ON'
   else:
     digital6 = 'OFF'
   if digital7 == 1:
    digital7 = 'ON'
   else:
     digital7 = 'OFF'
   if digital8 == 1:
    digital8 = 'ON'
   else:
     digital8 = 'OFF'
   sensor1_level = ReadChannel(sensor1_channel)
   sensor1_volts = ConvertVolts(sensor1_level,2)
   sensor2_level = ReadChannel(sensor2_channel)
   sensor2_volts = ConvertVolts(sensor2_level,2)
   sensor3_level = ReadChannel(sensor3_channel)
   sensor3_volts = ConvertVolts(sensor3_level,2)
   sensor4_level = ReadChannel(sensor4_channel)
   sensor4_volts = ConvertVolts(sensor4_level,2)
   sensor5_level = ReadChannel(sensor5_channel)
   sensor5_volts = ConvertVolts(sensor5_level,2)
   sensor6_level = ReadChannel(sensor6_channel)
   sensor6_volts = ConvertVolts(sensor6_level,2)
   sensor7_level = ReadChannel(sensor7_channel)
   sensor7_volts = ConvertVolts(sensor7_level,2)
   sensor8_level = ReadChannel(sensor8_channel)
   sensor8_volts = ConvertVolts(sensor8_level,2)
   if fdtime >= fstore:
     foldtime = fnewtime
     googlepage = "https://script.google.com/macros/s/"
     mygooglekey = "AKfycbysdfsdfsdfsdfskqtjr_0wSgFJasKfqR6s21QtdsaLeO9oJMhUqzF7Bs" //
     wtime = time.strftime("%d/%m/%Y %H:%M:%S")
     content = urllib.urlopen("%s%s/exec?DATE=%s&Sensor1=%s&Sensor2=%s&Sensor3=%s&Sensor4=%s&Sensor5=%s&Sensor6=%s&Sensor7=%s&Sensor8=%s&Digital1=%s&Digital2=%s&Digital3=%s&Digital4=%s&Digital5=%s&Digital6=%s&Digital7=%s&Digital8=%s" %(googlepage, mygooglekey, wtime, sensor1_volts, sensor2_volts, sensor3_volts, sensor4_volts, sensor5_volts, sensor6_volts, sensor7_volts, sensor8_volts, digital1, digital2, digital3, digital4, digital5, digital6, digital7, digital8)).read()
     print "-----------------------------------------------------------------------------"
     print(" Sensor-1            Sensor-2         Sensor-3          Sensor-4         Sensor-5            Sensor-6         Sensor-7          Sensor-8")
     print(" {} - ({}V)        {} - ({}V)      {} - ({}V)      {} - ({}V)          {} - ({}V)          {} - ({}V)     {} - ({}V)        {} - ({}V)".format(sensor1_level,sensor1_volts,sensor2_level,sensor2_volts,sensor3_level,sensor3_volts,sensor4_level,sensor4_volts,sensor5_level,sensor5_volts,sensor6_level,sensor6_volts,sensor7_level,sensor7_volts,sensor8_level,sensor8_volts))
     print(" Digital-1            Digital-2         Digital-3          Digital-4         Digital-5            Digital-6         Digital-7          Digital-8")
     print(" {}                  {}                  {}                 {}                    {}                    {}                {}                 {} ".format(digital1,digital2,digital3,digital4,digital5,digital6,digital7,digital8))
time.sleep(delay)
Selamlar,
Coskun Kozakbas
cactiapps.blogspot.com
coskukoz
Re: 8 Analog - 8 Digital Input Raspberry Pi Prototype
Fri Apr 29, 2016 6:38 am
