Marcepan
Two wire temperature sensor
Tue Apr 12, 2016 6:08 pm
Hey guys,
Was wondering whether I could connect sensor from the picture to the Pi. It's currently hooked up with some generic PCB that was mounted to PC case. If it was possible, how should I tackle it?
Thanks.
klricks
Re: Two wire temperature sensor
Thu Apr 14, 2016 12:58 pm
Marcepan wrote:Hey guys,
Thanks.
The sensor can't be directly connected to the RPi.
That is a temperature bead which is like a resistor that changes value as the temperature changes. It would need additional electric circuits to convert from resistance to voltage. Then more circuits to convert from voltage to digital. (Analog to Digital)
This is probably what the 'generic PCB' is doing.
grahamed
Fri Apr 15, 2016 10:57 pm
Hi
Looks like a K-type thermocouple. If it is then MAX6675 looks like a good solution. The plug is often a clue.
Marcepan
Mon Apr 18, 2016 9:10 pm
I'll post another pic tomorrow to show you guys how it's plugged in to the 'PCB', however I'll probably just buy separate probe off eBay soon.
