Massi
Temperature humidity sensor DSTH01
Wed Apr 06, 2016 1:36 pm
Hello all,
i'm looking for something new in my setup, so even if i already have a couple of dht22 sensorrs i was looking with interest to this i2c sensor.
But before buying it, i've a couple of questions:
- is there a clean way to convert the 1,27mm pitch spacing to the common (and widely used) 2.54mm? i'd like to avoid strange soldering..
- the datasheet talks about something i'd never seen for a i2c device
If the DSTH01 module shares the I2C bus with other slave devices, it should be powered down when the master controller is communicating with the other slave devices, which can be realized either by setting /CS to logic high or setting the VCC pin to 0V.
is this true? what's the meaning of an i2c device if i have to power it off when i use the bus? anyone tried this sensor and can confirm?
Then i'm quite curious about the heater use, but i'll eventually look into that :)
brekee12
Re: Temperature humidity sensor DSTH01
Wed Apr 06, 2016 3:12 pm
Did you looked up the chinese version of the DHT22 or the original one? I have experience with the chinese one. It has sleeping mode, so first it has to wake-up by addressing and after a while it works normally. It happens; because, it is used as one wire equipment also. Maybe, the original DHT has similar requironment and the quoted text is about the one wire option.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
joan
Wed Apr 06, 2016 5:46 pm
Have you looked at the si7021?
Massi
Wed Apr 06, 2016 7:59 pm
joan wrote:Have you looked at the si7021?
didn't know that
seems nice
let's buy one :)
joan
Tue Apr 12, 2016 3:25 pm
Coincidentally my Si7021 arrived today.
I bought http://www.ebay.co.uk/itm/272096714499
Looks good.
I did an hours worth of readings.
Temperature and relative humidity
Temperature
Relative humidity
#!/usr/bin/env python
import time
import pigpio # http://abyz.co.uk/rpi/pigpio/python.html
Code to read the Si7021 temprature and relative humidity sensor.
The sensor uses I2C to communicate.
BUS=1
ADDR=0x40
pi = pigpio.pi()
if not pi.connected:
   exit(0)
h = pi.i2c_open(BUS, ADDR)
stop = time.time() + 3600
while time.time() < stop:
   # RH
   pi.i2c_write_device(h, [0xF5]) # RH no hold
   time.sleep(0.1)
   c, rh = pi.i2c_read_device(h, 3) # msb, lsb, checksum
   rh_val = (rh[0]<<8) + rh[1]
   # RH (%) = ((125 * rh_val)/65536) - 6
   RH = ((125.0 * rh_val)/65536.0) - 6.0
   # T
   pi.i2c_write_device(h, [0xF3]) # T no hold
   time.sleep(0.1)
   c, t = pi.i2c_read_device(h, 3) # msb, lsb, checksum
   t_val = (t[0]<<8) + t[1]
   # Temperature (C) = ((175.72 * t_val)/65536) - 46.85
   T = ((175.72 * t_val)/65536.0) - 46.85
   print("{:.2f} {:.2f}".format(T, RH))
   time.sleep(1)
pi.i2c_close(h)
pi.stop()
Massi
Tue Apr 12, 2016 3:36 pm
i hate your postal service :) i'll have to wait somewhere near a month for mine..
could you please try a comparison with a DHT22? i'm quite curious about that (and i'm planning to replace my outside DHT22 with the new i2c..)
fruit-uk
Tue Apr 12, 2016 3:43 pm
I have several Si7021 around the house - running on panStamps though.
They have been very reliable so far
joan
Tue Apr 12, 2016 4:14 pm
Massi wrote:i hate your postal service :) i'll have to wait somewhere near a month for mine..
I ordered on the 28th March, so I was ahead of you.
I'll see if can set up a DHT11/DHT22/Si7021 running and leave them for a few hours.
The Si7021 has a fixed I2C address so one per bus.
Re first post.
Probably means other DSTH01 (same address) on the same bus.
joan
Wed Apr 13, 2016 7:37 pm
I left a Pi plus DHT11/DHT22/Si7201 under a plastic tub for seven hours, taking a reading every 3.3 seconds.
The DHT22 and Si7021 are clearly in the same ball park. The Si7021 seems to have a lot less jitter.
Relative Humidity %
Temperature C
I left the DHT11 off this plot as it obscured the view of the other two sensors. It had broad bands as above.
Massi
Sat May 07, 2016 7:01 pm
eventually, i got it :)
so i wrote a full class for it
#!/usr/bin/env python3
#coding=utf-8
import time
import pigpio
#python class for Si7021 Temp-Humidity Sensor
class SI7021:
	#sensor has fixed address
	address = 0x40
	maxHeatLevel = 2 #this is 16mA, enough for me.. 15 would be 95 (!!) mA
	#RH Conversion Times
	#max conversion time for RH reading. In ms. 12,11,10 and 8 bit
	HtConvRh = 12
	MHtConvRh = 7
	MLtConvRh = 4.5
	LtConvRh = 3.1
	#Temp Conversion Times
	#max conversion time for TEMP reading. In ms. 14,13,12 and 11 bit
	HtConvTemp = 10.8
	MHtConvTemp = 6.2
	MLtConvTemp = 3.8
	LtConvTemp = 2.4
	HtConvFull = HtConvRh + HtConvTemp
	MHtConvFull = MHtConvRh + MHtConvTemp
	MLtConvFull = MLtConvRh + MLtConvTemp
	LtConvFull = LtConvRh + LtConvTemp
	#time of powerup after reset. In ms.
	resetTime = 15
	#commands
	HumHoldCmd = 0xE5 #Measure Relative Humidity, Hold Master Mode
	HumNoHoldCmd = 0xF5 #Measure Relative Humidity, No Hold Master Mode
	TempHoldCmd = 0xE3 #Measure Temperature, Hold Master Mode
	TempNoHoldCmd = 0xF3 #Measure Temperature, No Hold Master Mode
	TempLastRhCmd = 0xE0 #Read Temperature Value from Previous RH Measurement
	SensorResetCmd = 0xFE
	D7-D0 Measurement Resolution:
		RH 		Temp
	00	12 bit	14 bit
	01	 8 bit 	12 bit
	10	10 bit 	13 bit
	11	11 bit 	11 bit
	D2 HTRE
	1 = On-chip Heater Enable
	0 = On-chip Heater Disable
	WriteUserRegCmd = 0xE6 #Write User Register
	ReadUserRegCmd = 0xE7 #Read User Register
	For heater, write 4 LSB of register. From 0000 to 1111, from 3mA to 95mA power consumption
	WriteHeatRegCmd = 0x51 #Write Heater Control Register
	ReadHeatRegCmd = 0x11 #Read Heater Control Register
	FirmwareRevCmd = [0x84,0xB8] #Read Firmware Revision
	checksum byte is calculated using a CRC generator polynomial of x8 + x5 + x4 + 1, with an initialization of 0x00
	ReadIDlowCmd = [0xFA,0x0F] #Read Electronic ID 1st Byte
	ReadIDhighCmd = [0xFC,0xC9] #Read Electronic ID 2nd Byte
	def __init__(self, bus=1, debug=False):
		self.debug = debug
		self.pi = pigpio.pi()
		self.i2c = self.pi.i2c_open(bus, self.address, 0)
	def resetSensor(self):
		self.pi.i2c_write_device(self.i2c, [self.SensorResetCmd])
		time.sleep(self.resetTime/1000.0)
	def readRH(self,hold=False):
		#check what resolution is set up
		resolution = self.getRes()
		if resolution == 0b00: sleepTime = self.HtConvFull/1000.0
		elif resolution == 0b01: sleepTime = self.MHtConvFull/1000.0
		elif resolution == 0b10: sleepTime = self.MLtConvFull/1000.0
		else: sleepTime = self.LtConvFull/1000.0
		#now start a new conversion
		if hold: command = self.HumHoldCmd
		else: command = self.HumNoHoldCmd
		self.pi.i2c_write_device(self.i2c, [command])
		#wait for the reading to end
		time.sleep(sleepTime)
		c, rh = self.pi.i2c_read_device(self.i2c, 3) # msb, lsb, checksum
		#check the checksum.. to be implemented
		if self.checkChecksum(rh) > 0:
			raise Exception("Wrong Checksum in RH reading")
		value = (rh[0]<<8) + rh[1]
		return min(max(0.0,((125.0*value)/65536.0)-6.0),100.0)
	def readTemp(self,hold=False,last=False,checksum=False):
		#i'f i'm requesting the last converted temp (in a RH read) i can skip half function
		if last:
			command = self.TempLastRhCmd
			sleepTime = 0
		else:
			if resolution == 0b00: sleepTime = self.HtConvTemp/1000.0
			elif resolution == 0b01: sleepTime = self.MHtConvTemp/1000.0
			elif resolution == 0b10: sleepTime = self.MLtConvTemp/1000.0
			else: sleepTime = self.LtConvTemp/1000.0
			if hold: command = self.TempHoldCmd
			else: command = self.TempNoHoldCmd
		c, t = self.pi.i2c_read_device(self.i2c, 3) # msb, lsb, checksum
		#check the checksum.. to be implemented reading IDs
		if self.checkChecksum(t) > 0:
			raise Exception("Wrong Checksum in Temp reading")
		value = (t[0]<<8) + t[1]
		return ((175.72*value)/65536.0)-46.85
	def readUserReg(self):
		self.pi.i2c_write_device(self.i2c, [self.ReadUserRegCmd])
		regValue = self.pi.i2c_read_byte(self.i2c) # reg value
		return regValue
	def readHeatReg(self):
		self.pi.i2c_write_device(self.i2c, [self.ReadHeatRegCmd])
		return regValue
	def writeUserReg(self,data):
		self.pi.i2c_write_device(self.i2c, [self.WriteUserRegCmd, data])
	def writeHeatReg(self,data):
		if data > maxHeatLevel: raise ValueError("Heat Level too high")
		self.pi.i2c_write_device(self.i2c, [self.writeHeatRegCmd, data])
	def setRes(self,resolution):
		#we have 4 levels. 0-3? but inverted (in the reg 00 is the highest)
		if resolution not in range(0,4): raise ValueError("Resolution must be in range 0-3")
		#inverting the range
		resolution = 3-resolution
		#exploding bits
		resMSB = resolution>>1&1
		resLSB = resolution&1
		#getting actual register
		reg = self.readUserReg()
		#bitwising it
		reg = self.setBit(reg,resMSB,7)
		reg = self.setBit(reg,resLSB,0)
		#writing it back to the device
		self.writeUserReg(reg)
	def getRes(self):
		userReg = self.readUserReg()
		return((userReg>>0&1) | (userReg>>7&1)<<1)
	def heaterControl(self,power=0,level=0):
		#power control!
		#bitwising it
		reg = self.setBit(reg,power,2)
		#level control
		self.writeHeatReg(level)
	def checkChecksum(self,data):
		rem = 0
		for b in data:
			rem ^= b
			for bit in range(8):
				if rem & 128:
					rem = (rem << 1) ^ 0x131
				else:
					rem = (rem << 1)
		return rem & 0xFF
	def getFirmwareRev(self):
		self.pi.i2c_write_device(self.i2c, self.FirmwareRevCmd)
		return regValue
	def getSerial(self):
		self.pi.i2c_write_device(self.i2c, self.ReadIDlowCmd)
		c, resultLow = self.pi.i2c_read_device(self.i2c, 8)
		self.pi.i2c_write_device(self.i2c, self.ReadIDhighCmd)
		c, resultHigh = self.pi.i2c_read_device(self.i2c, 6)
		crc = (resultLow[1],resultLow[3],resultLow[5],resultLow[7],resultHigh[2],resultHigh[5])
		serial = (resultLow[0],resultLow[2],resultLow[4],resultLow[6],resultHigh[0],resultHigh[1],resultHigh[3],resultHigh[4])
		if 	self.checkChecksum((resultLow[0],resultLow[1])) or \
			self.checkChecksum((resultLow[0],resultLow[2],resultLow[3])) or \
			self.checkChecksum((resultLow[0],resultLow[2],resultLow[4],resultLow[5])) or \
			self.checkChecksum((resultLow[0],resultLow[2],resultLow[4],resultLow[6],resultLow[7])) or \
			self.checkChecksum((resultHigh[0],resultHigh[1],resultHigh[2])) or \
			self.checkChecksum((resultHigh[0],resultHigh[1],resultHigh[3],resultHigh[4],resultHigh[5])):
			raise Exception("Checksum error in Serial")
		return (resultLow[0]<<56)|(resultLow[2]<<48)|(resultLow[4]<<40)|(resultLow[6]<<32)|(resultHigh[0]<<24)|(resultHigh[1]<<16)|(resultHigh[3]<<8)|resultHigh[4]
	def setBit(self,byte,bit,index):
		#Set the index:th bit of byte to bit, and return the new value.
		mask = 1 << index
		byte &= ~mask
		if bit:
			byte |= mask
		return byte
	def close(self):
		self.pi.i2c_close(self.i2c)
		self.pi.stop()
if __name__ == "__main__":
	sensor = SI7021()
	print("User Reg: {:8b}".format(sensor.readUserReg()))
	print("Heat Reg{:8b}".format(sensor.readHeatReg()))
	print("Resolution: {:2b}".format(sensor.getRes()))
	print("RH: {}".format(sensor.readRH()))
	print("Temp {}".format(sensor.readTemp()))
	print("Firmware: {:x}".format(sensor.getFirmwareRev()))
	print("Serial: {}".format(sensor.getSerial()))
	sensor.close()
but how to check the checksum??
what does this mean?
The
checksum byte is calculated using a CRC generator polynomial of x8 + x5 + x4 + 1, with an initialization of 0x00.
and why is it needed to read the id?
Edit: reviewed code to add joan's crc :)
joan
Sat May 07, 2016 7:20 pm
Here is some code I started but has been on the back burner (i.e. I have been doing other things instead).
I don't think it was that far off being okay but I hadn't finished testing. Make of it what you will.
import time
Code      Command
0xE5      Measure Relative Humidity, Hold Master Mode
   MSB LSB CRC
0xF5      Measure Relative Humidity, No Hold Master Mode
   MSB LSB CRC
0xE3      Measure Temperature, Hold Master Mode
   MSB LSB CRC
0xF3      Measure Temperature, No Hold Master Mode
   MSB LSB CRC
0xE0      Read Temperature Value from Previous RH Measurement
   MSB LSB
0xFE      Reset
0xE6 VAL  Write RH/T User Register 1
   D7   D6   D5   D4   D3   D2   D1   D0
   RES1 VDDS RSVD RSVD RSVD HTRE RSVD RES0
   RES:  RH/T 0 12/14, 1 8/12, 2 10/13, 3 11/11
   VDDS: 0 okay, 1 low
   HTRE: 0 heater disable, 1 heater enable
0xE7      Read RH/T User Register 1
   VAL
0x51 VAL  Write Heater Control Register
   RSVD RSVD RSVD RSVD HTR3 HTR2 HTR1 HTR0
   HTR: mA 0 3.09, 1 9.18, 2 15.24, 4 27.39, 8 51.69, 15 94.2
0x11      Read Heater Control Register
   VAL
0xFA 0x0F Read Electronic ID 1st Byte
   SNA_3 CRC SNA_2 CRC SNA_1 CRC SNA_0 CRC
0xFC 0xC9 Read Electronic ID 2nd Byte
   SNB_3 CRC SNB_2 CRC SNB_1 CRC SNB_0 CRC
   SNB_3: 0x00 sample, 0x0D 7013, 0x14 7020, 0x15 7021, 0xFF sample
0x84 0xB8 Read Firmware Revision
   REV
   REV: 0xFF 1.0, 0x20 2.0
class sensor:
   def __init__(self, pi, bus=1, addr=0x40):
      self.pi = pi
      self._h = pi.i2c_open(bus, addr)
   def close(self):
      self.pi.i2c_close(self._h)
   def temperature(self):
      self.pi.i2c_write_device(self._h, [0xF3]) # T no hold
      time.sleep(0.1)
      c, t = self.pi.i2c_read_device(self._h, 3) # msb, lsb, checksum
      if self._crc(t) == 0:
      else:
         T = 999
      return T
   def humidity(self):
      self.pi.i2c_write_device(self._h, [0xF5]) # RH no hold
      time.sleep(0.1)
      c, rh = self.pi.i2c_read_device(self._h, 3) # msb, lsb, checksum
      if self._crc(rh) == 0:
      else:
         RH = 999
      return RH
   def switch_heater_on(self):
      # read register and only update heater bit
      self.pi.i2c_write_device(self._h, [0xE7])
      c, val = self.pi.i2c_read_device(self._h, 1)
      v = (val[0] & 0xFB) | 4
      self.pi.i2c_write_device(self._h, [0xE6, v])
   def switch_heater_off(self):
      v = (val[0] & 0xFB)
   def set_resolution(self, res):
      # read register and only update resolution bits
      v = (val[0] & 0x7E) | (res & 1) | ((res & 2)<<6)
   def get_resolution(self):
      v = ((val[0]&128)>>6) | (val[0]&1)
      return v
   def set_heater_level(self, level):
      # read register and only update heater bits
      self.pi.i2c_write_device(self._h, [0x11])
      v = (val[0] & 0xF0) | (level & 0x0F)
      self.pi.i2c_write_device(self._h, [0x51, v])
   def get_heater_level(self):
      c, level = self.pi.i2c_read_device(self._h, 1) # level
      return level[0]&0x0F
   def firmware_revision(self):
      self.pi.i2c_write_device(self._h, [0x84, 0xB8])
      c, rev = self.pi.i2c_read_device(self._h, 1) # rev
      return rev[0]
   def electronic_id_1(self):
      self.pi.i2c_write_device(self._h, [0xFA, 0x0F])
      c, id1 = self.pi.i2c_read_device(self._h, 8) # id1
      return (id1[0]<<24)|(id1[2]<<16)|(id1[4]<<8)|id1[6]
   def electronic_id_2(self):
      self.pi.i2c_write_device(self._h, [0xFC, 0xC9])
      c, id2 = self.pi.i2c_read_device(self._h, 8) # id2
      return (id2[0]<<24)|(id2[2]<<16)|(id2[4]<<8)|id2[6]
   def _crc(self, data):
      rem = 0
      for b in data:
         rem ^= b
            if rem & 128:
               rem = (rem << 1) ^ 0x31
            else:
               rem = (rem << 1)
      return rem & 0xFF
   import time
   import Si7021
   import pigpio
   pi = pigpio.pi()
      exit(0)
   s = Si7021.sensor(pi)
   s.set_resolution(0)
   print("res=", s.get_resolution())
   stop = time.time() + 10
   print("revision={:x} id1={:08x} id2={:08x}".format(s.firmware_revision(),
      s.electronic_id_1(), s.electronic_id_2()))
      print("{:.2f} {:.2f}".format(s.temperature(), s.humidity()))
      time.sleep(1)
   s.close()
   pi.stop()
The CRC for the electronic ids don't work as I expected. It seems to work for the first four bytes (from memory, I haven't got one set-up at the moment, each CRC appears to be for the preceding bytes, so the first CRC is for SNA_3, second CRC is for SNA_3 and SNA_2, third CRC is for SNA_3, 2, 1, and fourth CRC is for SNA_3, 2, 1, 0).
I can't make it work at all for the second four bytes of the electronic id.
Massi
Sat May 07, 2016 7:33 pm
well more or less we did the same for code :)
but what's that 0x31 in the crc function?
shouldn't it be 0x131 starting from the polynomial function?
x8+x5+x4+x should be 0b100110001, so 0x131
am i wrong?
i'll try to get what you did :)
joan
Sat May 07, 2016 7:37 pm
Massi wrote:well more or less we did the same for code :)
am i wrong?
I used to understand CRCs and error correction codes etc. but through lack of use I've forgotten most of what I knew.
You can use 0x131 if you want, it should have the same result, as the CRC is truncated to be 8 bits.
Massi
Sat May 07, 2016 7:52 pm
am i wrong?
Fancy that, it's all working!
So as you said for the first command (8 bytes) every CRC is related to all what is before:
And for the second command (6 bytes) it's the same:
CRC1 is for SNB_3 and SNB_2
CRC2 is for SNB_3, SNB_2, SNB_1 and SNB_0
Thanks a lot :)
Edit: in your code i see you read 8 bytes even for the second serial call, but in the datasheet it's 6bytes long. Maybe that's why you can't check checksums?
joan
Sat May 07, 2016 8:04 pm
Massi wrote: ...
Almost certainly, I don't know how I managed to misread the pdf, but I did! :(
Massi
Sat May 07, 2016 8:09 pm
well now it works, WE fixed it :)
with the si7021 i got also a bmp280, i'm gonna try also that
joan
Sat May 07, 2016 9:01 pm
Massi wrote:well now it works, WE fixed it :)
I updated my code to correctly read the second four bytes of the electronic Id.
# Si87021.py
# Public Domain
# 2016-05-07
import time
Code      Command
   MSB LSB CRC
   MSB LSB CRC
   MSB LSB CRC
   MSB LSB CRC
   MSB LSB
0xFE      Reset
   VDDS: 0 okay, 1 low
   VAL
   VAL
   SNB_3 SNB_2 CRC SNB_1 SNB_0 CRC
   REV
class sensor:
      self.pi = pi
   def close(self):
      time.sleep(0.1)
      else:
         T = 999
      return T
   def humidity(self):
      time.sleep(0.1)
      else:
         RH = 999
      return RH
      v = (val[0] & 0xFB)
      return v
      return rev[0]
      if self._crc([id1[0], id1[2], id1[4], id1[6]]) == id1[7]:
      else:
         return 0
      c, id2 = self.pi.i2c_read_device(self._h, 6) # id2
      if self._crc([id2[0], id2[1], id2[3], id2[4]]) == id2[5]:
         return (id2[0]<<24)|(id2[1]<<16)|(id2[3]<<8)|id2[4]
      else:
         return 0
      rem = 0
      for b in data:
         rem ^= b
            if rem & 128:
            else:
               rem = (rem << 1)
      return rem & 0xFF
   import time
   import Si7021
   import pigpio
   pi = pigpio.pi()
      exit(0)
   s.set_resolution(0)
      time.sleep(1)
   s.close()
   pi.stop()
Massi
Mon May 09, 2016 12:58 pm
am i wrong or even clock stretching is working with this device?
i expected it to fail with a raspi, but executing the reading with the hold is working for me..
(btw, my sensor is a rev. 1.0 and it's new, lol, where's the 2.0?)
joan
Mon May 09, 2016 1:39 pm
Massi wrote:am i wrong or even clock stretching is working with this device?
My sensor returns 0xFF (for a Rev. 1.0) as well.
I didn't try the clock stretching mode. I will try later, perhaps tonight. Perhaps the i2c_bcm2708 driver has been updated. I know someone gave a clock stretching patch with a request for it to be included in the driver.
Massi
Mon May 09, 2016 2:04 pm
well i have to admit that at my level of noobness i just tried using the 0xE5 - 0xE3 commands, and i got the same results than 0xF5 - 0xF3 commands.
i did not look to piscope so maybe i'm completely wrong :)
Massi
Tue May 10, 2016 6:30 pm
i was going to install the sensor in it's final position (that is outside) and.. surprise!
i can't see it!
e checked connections 3 times
i exchanged it with other i2c sensors
i tried with 5v
nothing!
any idea?
it's working perfectly inside, and i don't think it's a matter of distance because:
- i have a range extender for i2c bus in the middle
- all other sensors work flawlessly
- i also tried adding a PCA9548 next to the sensor
ideas?
i'm so sad :(
joan
Tue May 10, 2016 6:52 pm
Massi wrote:i was going to install the sensor in it's final position (that is outside) and.. surprise!
i can't see it!
i tried with 5v
nothing!
any idea?
ideas?
i'm so sad :(
All I can suggest is to lower the bus speed.
/boot/config.txt
dtparam=i2c_baudrate=50000
All my connections are just a few inches.
Massi
Tue May 10, 2016 7:12 pm
i already tried :(
but at 400k everything else is working.. this isn't working even at 100k
i really can't understand this..
Massi
Wed May 11, 2016 10:06 am
the sensor should have an embedded 10k pullup resistor, do you think it can be a good idea to strengthen it adding, i.e., another 10k in parallel?
joan
Wed May 11, 2016 10:12 am
Massi wrote:the sensor should have an embedded 10k pullup resistor, do you think it can be a good idea to strengthen it adding, i.e., another 10k in parallel?
No idea. I have to assume there is some interaction with the I2C extender. You may need to open a new post mentioning the Si7021 by name. The people who can help may not be reading this thread.
