YodaVonBeck
Easy project
Wed Mar 16, 2016 3:37 pm
So as another start project I was think of making a water proof temperature gauge for brewing beer.
So, I was thinking of using this : http://www.reuk.co.uk/DS18B20-Temperatu ... rry-Pi.htm
But with a waterproof sensor like this : http://www.etotal.dk/product/temperatur ... ire-1m-92/
And setup like this : https://learn.adafruit.com/adafruits-ra ... g/hardware
Would that work do you think?
scotty101
Re: Easy project
Wed Mar 16, 2016 4:39 pm
Yes. It would work.
Good luck.
YodaVonBeck
Re: Easy project
Wed Mar 16, 2016 9:56 pm
OK, so I tried to find the different components in Denmark, but the PI Cobbler and cable is not available.
How would this setup look with that and simply "just" the breadboard and wires and components? (I can get those)
BMS Doug
Re: Easy project
Thu Mar 17, 2016 8:45 am
YodaVonBeck wrote:OK, so I tried to find the different components in Denmark, but the PI Cobbler and cable is not available.
The Pi Cobbler helps everything look tidier while prototyping, it's not in any way essential.
A bunch of Female to male Dupont cables would do the job, they tend to come still connected as a ribbon so you should be able to keep your project reasonably tidy.
Doug.
YodaVonBeck
Re: Easy project
Fri Apr 01, 2016 8:51 am
OK, so I got it all setup. The Pi can see the deviced and I can read data from it, but in the code example I used, it comes up with this error:
File "temperature3.py", line 7, in <module>
tempdata = thetext.split("/n")[1].split(" ")[9]
IndexError: list index out of range
This is code being run:
Any idea of what the problem is?
saltydog
Re: Easy project
Fri Apr 01, 2016 9:18 am
adding print lines is a great way to debug.
Just before line 7 in the file temperature3.py
can you add a line:
print(thetext)
YodaVonBeck
Re: Easy project
Fri Apr 01, 2016 10:00 am
Thanks - good idea.
It gave me this text, so it does contain data, but I am not sure where the code then breaks as I am not familiar with the "split" function
[email protected]:~/MyCode $ sudo python temperature3.py
6c 01 4b 46 7f ff 04 10 5d : crc=5d YES
6c 01 4b 46 7f ff 04 10 5d t=22750
File "temperature3.py", line 8, in <module>
saltydog
Re: Easy project
Fri Apr 01, 2016 10:09 am
try changing
to:
tempdata = thetext.split("\n")[1].split(" ")[9]
YodaVonBeck
Re: Easy project
Fri Apr 01, 2016 10:19 am
That worked!
Thanks - I must have missed that in the review of the code :(
So now I can pull data and write it.
I already have the code to act differently within certain temperatures and I just need to add the GPIO code to make the LEDs light up:
import time
while 1:
tempfile = open("/sys/bus/w1/devices/28-0000065657f0/w1_slave")
thetext = tempfile.read()
tempfile.close()
temperature = float(tempdata[2:])
temperature = temperature/1000
# Temp 61.0-63.0 GREEN
# Temp 59.9-60.9 RED & GREEN
# Temp < 58.9 RED
# Temp 63.1-65.0 RED & GREEN
# Temp > 65.1
print temperature
if (temperature>=61.0 and temperature<=63):
print "GREEN"
if (temperature>63 and temperature<=65):
print "GREEN & RED HIGH"
if (temperature>65):
print "RED HIGH"
if (temperature<61 and temperature>60):
print "GREEN & RED LOW"
if (temperature<=60):
print "RED LOW"
omegaman477
Re: Easy project
Tue Feb 28, 2017 1:45 pm
I have used 1 wire temp sensors for industrial and immersion applications for years. Mostly I pot the sensor in a length of rigid tubing (glass, polycarb, copper, S/S) in all cases the tube has one end properly sealed, a good blob of heat shrink compound on the sensor before you shove it into the tube. Use a low viscosity potting compound (good old 2 part slow cure epoxy works well. If you can then put it in a vacuum pot to suck out the air bubbles, then great but not essential.
Put a knot in the lead which is trapped by the potting agent to act as a strain relief.
Test your wiring, soldering well before potting. Insulate all the leads well with HS tube before potting.
..the only thing worse than a stupid question is a question not asked.
