vekfra
Read actual vales from the BeeWi BBW200 - Smart Clim
Sat Mar 12, 2016 5:55 pm
I recently purchased some BeeWi equipment from ibood (one time offer) and wanted to handle it in OpenHab.
. 2 Smart Tracker BBD100-A10
. 2 Smart Temperature & Humidity Sensor BBW200-A1
. 1 Smart LED Color Bulb BBL227-A1
As there is no binding for BeeWi I started with the beewibulb script from Stephanie Maks viewtopic.php?f=37&t=117729 with the update from Gerrit Hannaert and got that running.
Next I wanted to get the information from the BeeWi 'BBW200 - Smart Temperature & Humidity Sensor'
This script reads the actual temperature, humidity, battery status and the device information. The historical data is not handled yet.
Future step would be to create a rule in OpenHab using the knowledge gathered.
Some output of the script:
pi@raspberrypi:~ $ sudo ./beewiclim.py
Correct usage is "[sudo] beewiclim.py <device address> <command> [hci device]"
       <device address> in the format XX:XX:XX:XX:XX:XX
       Commands:  stat          - Get status
       Commands:  val           - Get values (temperature, humidity, battery)
       Commands:  raw           - Get values (temperature, humidity, battery)
       [hci device] i.e. hci1 in case of multiple devices
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' stat
Device name       = BeeWi SmartClim 1
Model number      = BeeWi BBW200
Serial number     =
Firmware revision = V1.5 R140514
Hardware revision = 1.0
Software revision =
Manufacturer       = Voxland
Temperature       = 19.5℃
Humidity          = 25%
Battery           = 97%
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' val
Temperature       = 19.5℃
Humidity          = 25%
Battery           = 97%
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' raw
19.5 25 97
The full Python script:
#!/usr/bin/env python2.7
#   A python script to read actual vales from the BeeWi 'BBW200 - Smart Temperature & Humidity Sensor'
#   BeeWi website: http://www.bee-wi.com/en.cfm
#   Missing: Read the historical temperature & humidity data (0x0039)
#   Tested on elelentary OS elementary OS 0.3.2 Freya >> BLE hardware: Broadcom Corp. BCM2045B (BDC-2.1) USB dongle
#   Tested on Raspberry 3
#   Don't kill me for the source, it's the first time I did something in Python.
#   Script based on the beewibulb.py script by Stephanie Maks >> Controlling a BeeWi SmartLite
#     https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=117729
#     Used the modicications of Gerrit Hannaert
#   Some fiddling with the bluetooth packet capture on Android, Wireshark, hcitool, hciconfig, GATTTool, apktool and testing, testing, testing.....
#   Many thanks to Stephanie Maks & Gerrit Hannaert
#   Stephanie Maks figured out with help from -- and thanks to -- the following sources:
#      http://stackoverflow.com/questions/24853597/ble-gatttool-cannot-connect-even-though-device-is-discoverable-with-hcitool-lesc
#      http://mike.saunby.net/2013/04/raspberry-pi-and-ti-cc2541-sensortag.html
#      https://github.com/sandeepmistry/node-yeelight-blue
#      https://www.nowsecure.com/blog/2014/02/07/bluetooth-packet-capture-on-android-4-4/
#   note: this needs to be called with 'sudo' or by root in order to work with some of the hci commands
import os
import sys
from subprocess import call, check_output
import time
def cycleHCI(s_hci) :
   # maybe a useless time waster but it makes sure our hci is starting fresh and clean
   # nope in fact we need to call this before each time we do hci or gatt stuff or it doesn't work
   call(['hciconfig', 's_hci', 'down'])
   time.sleep(0.1)
   call(['hciconfig', 's_hci', 'up'])
   time.sleep(0.1)
def getResultStringForDeviceMacHandle(s_hci, s_mac, s_handle) :
   # Read the string from handle
   raw_input = check_output(['gatttool', '-i', s_hci, '-b', s_mac, '--char-read', '--handle='+s_handle]);
   result_string = ''
   if ':' in raw_input:
      raw_list=raw_input.split(':')
      raw_data=raw_list[1]
      raw_data=raw_data.strip()
      octet_list=raw_data.split(' ')
      for octet in octet_list :
         j = int(octet, 16)
         if j > 31 and j < 127 : result_string += str(unichr(j))
   return result_string
def getActualValues(s_hci, s_mac) :
   # read the value characteristic (read handle is 0x003f)
   # handle returns 10 byte hex block containing temperature, humidity and batery level
   # the temperature consists of 3 bytes
   # Posivive value: byte 1 & 2 present the tenfold of the temperature
   # Negative value: byte 2 - byte 3 present the tenfold of the temperature
   raw_input = check_output(['gatttool', '-i', s_hci, '-b', s_mac, '--char-read', '--handle=0x003f']);
      raw_list    = raw_input.split(':')
      raw_data    = raw_list[1]
      raw_data    = raw_data.strip()
      octet_list  = raw_data.split(' ')
      t0 = int(octet_list[0], 16)
      t1 = int(octet_list[1], 16)
      t2 = int(octet_list[2], 16)
      if t2 == 255:
         temperature = (t1-t2)/10.0
      else:
         temperature = ((t0*255)+t1)/10.0
      humidity    = int(octet_list[4], 16)
      battery     = int(octet_list[9], 16)
   return (temperature, humidity, battery)
def getDeviceInfo(s_hci, s_mac) :
   # BeeWi Smart Climate handles
   # 0x0003 :    SmartClim name : 'Smart Clim'
   # 0x001b :      model number : 'BeeWi BBW200\00'
   # 0x001d :     serial number : '\00'
   # 0x001f : firmware revision : 'V1.5 R140514\00'
   # 0x0021 : hardware revision : '1.0\00'
   # 0x0023 : software revision : '\00'
   # 0x0025 :      manufacturer : 'Voxland\00'
   Name             = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0003')
   ModelNumber      = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001b')
   SerialNumber     = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001d')
   FirmwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001f')
   HardwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0021')
   SoftwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0023')
   Manufacturer     = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0025')
   return (Name, ModelNumber, SerialNumber, FirmwareRevision, HardwareRevision, SoftwareRevision, Manufacturer)
def printHelp() :
   print 'Correct usage is "[sudo] beewiclim.py <device address> <command> [argument]"'
   print '       <device address> in the format XX:XX:XX:XX:XX:XX'
   print '       Commands:  stat          - Get status'
   print '       Commands:  val           - Get values (temperature, humidity, battery)'
   print '       Commands:  raw           - Get values (temperature, humidity, battery)'
   print '       [hci device] i.e. hci1 in case of multiple devices'
   print ''
if __name__=='__main__' :
   if os.geteuid() != 0 :
      print 'WARNING: This script may not work correctly without sudo / root. Sorry.'
   if len(sys.argv) < 3 :
      printHelp()
   else :
      hci_device = 'hci0' # default
      device_address = sys.argv[1]
      command = sys.argv[2]
      command = command.lower()
      error = ''
      if len(sys.argv) == 4 : hci_device = sys.argv[3]
      hci_device = hci_device.lower()
      # address shortcuts
      if device_address == 'sc1' : device_address = '5C:31:3E:XX:XX:XX'
      if device_address == 'sc2' : device_address = 'D0:5F:B8:XX:XX:XX'
      if len(device_address) != 17 :
         print 'ERROR: device address must be in the format NN:NN:NN:NN:NN:NN'
         exit()
      if 'stat' in command :
         name, model, serial, frevision, hrevision, srevision, manufacturer = getDeviceInfo(hci_device, device_address)
         temperature, humidity, battery = getActualValues(hci_device, device_address)
         print '-------------------------------------'
         print 'Device name       = ' + name
         print 'Model number      = ' + model
         print 'Serial number     = ' + serial
         print 'Firmware revision = ' + frevision
         print 'Hardware revision = ' + hrevision
         print 'Software revision = ' + srevision
         print 'Manufaturer       = ' + manufacturer
         print 'Temperature       = ' + str(temperature) + u'\u2103'.encode("utf8") # encode("utf8") needed on raspberry
         print 'Humidity          = ' + str(humidity) + '%'
         print 'Battery           = ' + str(battery) + '%'
      if 'val' in command :
      if 'raw' in command :
         print str(temperature),str(humidity),str(battery)
      if error != '' :
         if error == 'off' : error = 'ERROR: SmartClim ' + device_address
         print error
   exit()
2016-03-16
Update for negative temperatures and positive values over 25.5 degrees Celcius
Busy on pulling the historical data (temperature & humidity), having some troebles translating the data into values.
And sorry for the language mistakes, English is not my native language
Cheers!
Dragafe
Re: Read actual vales from the BeeWi BBW200 - Smart Clim
Sun Mar 20, 2016 7:55 pm
Hi Vekfra, I see your post abd I want to ask you a question about Beewi's script. I have a bulb like Stephanie Marks and I want to use her script but it doesn't work. I can use "status" but it's the only code which I can use... You study her script and I want to know why It can't work ... Thanks.
PS : English isn't my native language.
deese
Sun May 08, 2016 11:31 pm
The script is quite good, but the temperature readings are not represented correctly.
I haven't checked with negative temperatures but with this patch I'm seeing the correct temperature.
Thanks for sharing the code!
--- beewiclim-orig.py   2016-05-08 23:26:48.120024401 +0000
+++ beewiclim.py    2016-05-08 23:28:20.679648390 +0000
@@ -70,9 +70,10 @@
       if t2 == 255:
-         temperature = (t1-t2)/10.0
+         temperature = (t1+(t2<<8))/10.0
       else:
-         temperature = ((t0*255)+t1)/10.0
+         #temperature = ((t0*255)+t1)/10.0
+    temperature = (t1 + (t2<<8))/10.0
@@ -145,7 +146,7 @@
-         print 'Temperature       = ' + str(temperature) + u'\u2103'
+         print 'Temperature       = ' + str(temperature) #+ u'\u2103'.encode("utf8")
faabbiii
Tue Jun 21, 2016 6:53 pm
i need some help :?
I got the BeeWi BBW200-A10 and can connect it to my smartphone.
If i run hcitool scan i cant finde the BeeWi, but other Devices like my Smartphone.
I also try l2ping with the MAC of the BeeWi i got from the BeeWi App, but it only returns:
Can't connect: Host is down
I hope someone can help me :)
thx & greetz
Fabi
PS : Sorry, english isnt my native language.
vekfra
Thu Jun 23, 2016 6:38 pm
faabbiii wrote:Hi,
i need some help :?
thx & greetz
Fabi
Hi faabbii,
You cant find the BeeWi BBW200 using the "hcitool scan" command, the scan command is for Bluetooth only i.e. phone, tv, etc.
To scan for a Bluetooth 4.0 device (Bluetooth Low Energy or BLE) you have to use the command "hcitool lescan" and that is a neverending scan, you have to stop it using Ctrl+C.
Example output lescan:
sudo hcitool lescan
LE Scan ...
5C:31:3E:4D:C6:3F (unknown)
5C:31:3E:4D:C6:3F BeeWi SmartClim 1
D0:5F:B8:51:A0:5E (unknown)
D0:5F:B8:51:A0:5E BeeWi SmartClim 2
^C
A BeeWi SmartClim will send 2 resonses when a lescan is active, one response containing the data and a response containing the device name.
For the security minding people: Yes you can see the device id's of my devices, but there is no security in the device, I did not find it, anyone that does a lescan within 30 meters or less from the devices can see this data anyway.
Good luck with your testing.
vekfra
Version 2: Read actual vales from the BeeWi BBW200 - Smart C
Thu Jun 23, 2016 6:54 pm
The first example scanning the information from the BBW200 was setup by connecting to the device and reading the data, I found that this technique uses a lot of battery power, battery dead in 3 weeks, not 3 months.
Something new:
For my home setup of OpenHab I use the lescan without hcitool by BLE scanning in node.js using the noble addon. No connection to the devices needed.
The node.js code runs once and returns a json dataset. The script is called every minute in a openhab rule and the json data is used to update the openhab items.
The node.js code: scanBeeWi.js
var noble = require('noble');
var SC1 = false;
var SC1T = '';
var SC1H = '';
var SC1B = '';
var SC2 = false;
var SC2T = '';
var SC2H = '';
var SC2B = '';
var TP1 = false;
var TP1S = "OFF"
var Count = 0;
function hexToInt(hex) {
    if (hex.length % 2 != 0) {
        hex = "0" + hex;
    var num = parseInt(hex, 16);
    var maxVal = Math.pow(2, hex.length / 2 * 8);
    if (num > maxVal / 2 - 1) {
        num = num - maxVal
    return num;
noble.on('stateChange', function(state) {
  if (state === 'poweredOn') {
    noble.stopScanning();
    noble.startScanning();
  } else {
noble.on('scanStop', function() {
    console.log('{"SC1Temp":"'+SC1T+'","SC1Humi":"'+SC1H+'","SC1Batt": "'+SC1B+'","SC2Temp":"'+SC2T+'","SC2Humi":"'+SC2H+'","SC2Batt": "'+SC2B+'","TPFrans":"'+TP1S+'"}');
    process.exit(0);
// Scan for the 3 devices (maximum 20 replies)
noble.on('discover', function(peripheral) {
    if ((peripheral.id == '5c313e4dc63f' || peripheral.id == 'd05fb851a05e')) {
        var data = peripheral.advertisement.manufacturerData.toString('hex');
        var Temp = parseFloat(hexToInt(data.substr(10, 2)+data.substr(8, 2))/10).toFixed(1);
        var Hum = Math.min(100,parseInt(data.substr(14, 2),16));
        var Bat = parseInt(data.substr(24, 2),16);
        if (!SC1 && peripheral.id == '5c313e4dc63f') {
            SC1 = true;
            SC1T = Temp;
            SC1H = Hum;
            SC1B = Bat;
        if (!SC2 && peripheral.id == 'd05fb851a05e') {
            SC2 = true;
            SC2T = Temp;
            SC2H = Hum;
            SC2B = Bat;
    // TrackerPad
    if (peripheral.id == '5c313e4dc63f') {
        TP1 = true;
        TP1S = 'ON';
    if ((Count > 20 || TP1) && (SC1 && SC2)) {
    Count = Count + 1;
OpenHab rule using scanBeeWi.js
rule "Get BeeWi SmartClim data"
when
	System started or
	Time cron "0 * * * * ?"
then
	var String data
// Get BeeWi data (each item in json string)
	data = executeCommandLine("sudo /usr/local/bin/node /home/pi/scanBeeWi.js", 20000)
//	postUpdate(SC1data, data)
	postUpdate(SC1Temp,transform("JSONPATH","$.SC1Temp",data))
	postUpdate(SC1Humi,transform("JSONPATH","$.SC1Humi",data)
	postUpdate(SC1Batt,transform("JSONPATH","$.SC1Batt",data)
	postUpdate(SC2Temp,transform("JSONPATH","$.SC2Temp",data))
	postUpdate(SC2Humi,transform("JSONPATH","$.SC2Humi",data)
	postUpdate(SC2Batt,transform("JSONPATH","$.SC2Batt",data)
	postUpdate(TPFrans,transform("JSONPATH","$.TPFrans",data)
end
Happy testing :-)
enrimilan
Mon Apr 24, 2017 2:55 pm
Hey there!
First, I would like to thank you for sharing your code here, awesome!
I created a new repository for collecting different code examples in order to interact with the device:
https://github.com/enrimilan/BeeWi-BBW200-Reader
I hope this could be helpful too ^^
Regards
